WCCP is not working after ASR migration is done.
syjeon
Hi Alls.
We recently migrated with new ASR router. However, WCCP is not working, which is using for WAE traffic redirection.
I checked the WCCP configuration. however, I can't find any issue from wccp configuration on ASR router.
Please have seeing following configuration related wccp.
Global)
ip wccp check services all
ip wccp 61 redirect-list waas-redirect
ip wccp 62 redirect-list waas-redirect
Intf)
interface GigabitEthernet0/0/x
ip wccp 61 redirect out
ip wccp 62 redirect in
show ip access-list waas-redirect)
    270 deny tcp any eq 1719 any
    280 deny tcp any eq 1720 any
    290 deny tcp any eq 8443 any
    300 deny tcp any eq 689 any
    310 permit tcp any any
I confirmed that after migration is done, there was no issue for connectivity between ASR and WAAS.
Following is WAAS status;
Router Information for Service: TCP Promiscuous 61
        Routers Seeing this Wide Area Engine(2)
        Router Id       Sent To
        xxx.xxx.xxx.213  xxx.xxx.xxx.15
        xxx.xxx.xxx.7     xxx.xxx.xxx.139
        Routers not Seeing this Wide Area Engine
                -NONE-
        Routers Notified of from other WAE's
                -NONE-
        Multicast Addresses Configured
        Router Id       Sent To
                -NONE-
                -NONE-
I can't find any difference from configuration and issue with connectivity.
Can anyone help to check this issue? let me know if you need more inputs.
Thanks.
here is a link with a configuration sample for   ASR/WCCP ( mask assignment)
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/white_paper_c11_502351.html
Sample from the link above:
WAE#sh run | in wccp
wccp router-list 1 10.17.71.1
wccp tcp-promiscuous router-list-num 1 mask-assign assign-method-strict
wccp version 2
egress-method negotiated-return intercept-method wccp
Based on your current configuration  (redirect in & redirect out on the same int)  I suggest to use "redirect exclude in " on the interface going to the WAAS device to avoid possible routing loops. reference: http://www.ciscopress.com/articles/article.asp?p=1192686&seqNum=2
BR!
6 Replies 6
Felix Arrieta
what ASR software are you running ? did it change from the previous ASR?
from the ASR  can you get the following debugs:
#term mon
#debug ip wccp events
#debug ip wccp packets
#term no mon
#show ip wccp summary
#show ip wccp  61 detail
#show ip wccp  62 detail
I am not into ASR's bugs or any deep support  but I found someone else who face a similar issue, it seems to be fixed with the following commands:   ( https://supportforums.cisco.com/thread/2071855)
Router (conf)# ip wccp check services all
Router (conf)# no ip wccp variable-timers   ( hidden command)
WCCP variable timers is basically a feature for better failure response when a WCCP client goes down. I am not sure if this feature is even supported on  ISR but can give it a try.
I hope that helps, otherwise please share the ASR  debugs and  I'll try to find a better answer.
cheers!
Hi Felix,
I'm pasting the show output what you requested.
show ip wccp 61 de)
WCCP Client information:
        WCCP Client ID:          xxx.xxx.xxx.179
        Protocol Version:        2.0
        State:                   Usable
        Redirection:             GRE
        Packet Return:           GRE
        Assignment:              HASH
        Initial Hash Info:       FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                                 00000000000000000000000000000000
        Assigned Hash Info:      FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
        Hash Allotment:          128 (50.00%)
        Packets s/w Redirected:  0
        Connect Time:            1w3d
        Bypassed Packets
          Process:               0
          CEF:                   0
          Errors:                0
        WCCP Client ID:          xxx.xxx.xxx.178
        State:                   Usable
        Redirection:             GRE
        Packet Return:           GRE
        Assignment:              HASH
        Initial Hash Info:       00000000000000000000000000000000
        Assigned Hash Info:      00000000000000000000000000000000
        Connect Time:            1w3d
        Bypassed Packets
          Process:               0
          CEF:                   0
          Errors:                0
show ip wccp 62 de)
        State:                   Usable
        Redirection:             GRE
        Packet Return:           GRE
        Assignment:              HASH
        Connect Time:            1w3d
        Bypassed Packets
          Process:               0
          CEF:                   0
          Errors:                0
        State:                   Usable
        Redirection:             GRE
        Packet Return:           GRE
        Assignment:              HASH
        Connect Time:            1w3d
        Bypassed Packets
          Process:               0
          CEF:                   0
          Errors:                0
Could you check?
Thanks.
hi Syjeon,
can you change the assignment method from both  WAAS devices from HASH to MASK ?  then shut down the WCCP service from the WAAS devices  WAE(config)#no wccp version 2 wait till it  clear the WCCP session  then get it back again with   WAE(config)#wccp version 2
go back to the ASR and check if there is traffic being redirected now.
I wonder how the redirection really looks like, do you have something like this on your network:
ASR:
int fastethernet 1/0
description LAN traffic from branch office
ip wccp 61 redirect in
int serial 0/0
description WAN traffic going to Core office
for testing redirection:
WAAS# show wccp gre
Transparent GRE packets received:              5531561         <-----it should increment if redirection is working
Transparent non-GRE packets received:          0
from the ASR: ( we should see counters incrementing over here as well)
#sh platform software wccp interface counters
show platform software wccp 61 counters
show platform software wccp 62 counters
let me know how it goes,
We configured as following on ASR.
I couldn't see the counter increment with your provided show command.
Could you advise how to change the method from gre to hash? Do we need to change the config both of them?
Give us the usuful link.
Thanks.
wccp version 2
BR!
Thanks for your best support.
