How to change the Default Password on AP1131AG
Answered Question
Jul 24th, 2012
Hi all :
I tried to change the default password Cisco to other by command line but the password cannot work out.
The command line I used are as below :
AP#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
AP(config)#enable pass
AP(config)#enable password 4dMINO123 ?
LINE    <cr>
AP(config)#exit
AP#wr
*Mar  1 04:39:23.902: %SYS-5-CONFIG_I: Configured from console by console
Building configuration...
[OK]
AP#exit
This still cannot cahnge. Below I do again below commands :
AP(config)#enable secret
% Incomplete command.
AP(config)#enable secret ?
  0      Specifies an UNENCRYPTED password will follow
  5      Specifies an ENCRYPTED secret will follow
  LINE   The UNENCRYPTED (cleartext) 'enable' secret
  level  Set exec level password
AP(config)#enable secret 5
AP(config)#enable secret 5 ?
  LINE  The ENCRYPTED 'enable' secret string
AP(config)#enable secret 5 LINE
ERROR: The secret you entered is not a valid encrypted secret.
To enter an UNENCRYPTED secret, do not specify type 5 encryption.
When you properly enter an UNENCRYPTED secret, it will be encrypted.
AP(config)#enable secret LINE
AP(config)#exit
AP#
*Mar  1 04:40:53.021: %SYS-5-CONFIG_I: Configured from console by console
AP#
AP#exit
After that when I access with >en again as below with correct password of 4dMINO123 and it always fails as below :
Can anybody help to provide correct way of changing the default password of Cisco to another password? Many thanks!
AP con0 is now available
Press RETURN to get started.
AP>en
Password:
Password:
Password:
% Bad secrets
AP>en 0
AP>en 5
% No password set
AP>en 15
Password:
Password:
% Password:  timeout expired!
Password:
% Bad secrets
AP>
AP>
AP>en
Password:
Password:
Password:
% Bad secrets
thanks and best regards,
tangsuan
Correct Answer by Amjad Abdullah about 5 years 5 days ago
You are probably providing an encrypted password rather than unencrypted one.
Use this command:
enable secret 0
That should do it.
If you try to use "enable secret 5 " then the command expects an encrypted form of the secret, not a plain text secret. What you need to enter however on the prompt is the clear text secret.
Amjad
Overall Rating: 5 (3 ratings)
Correct Answer
Amjad Abdullah Tue, 07/24/2012 - 23:32
  • Red, 2250 points or more
Use this command:
enable secret 0
That should do it.
Amjad
pgasparovic Thu, 07/26/2012 - 06:39
Hi, I have even the worst problem,
that seems probably to to be never asked on Internet. After quick learning how to reset this creapy device, I can't get by no means the enable password in default config for this box, having read everywhere from Cisco guide through community pages to Google pages.. NOWHERE.
Question is : what else except Cisco, cisco, root, password... can solve this stupid issue?!? I expect some guru from responsible AP BU to answer this with definite answer, or someone from Cisco having mercy with me to contact such guy(s).
Here is my desperate situation :
Nothing from this page helped :
http://www.cisco.com/en/US/partner/products/hw/wireless/ps430/products_password_recovery09186a00800949d0.shtml#reset_ap_newer
Situation after hard reset:
Xmodem file system is available.
flashfs[0]: 26 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6879232
flashfs[0]: Bytes available: 9119744
flashfs[0]: flashfs fsck took 43 seconds.
Base ethernet MAC Address: 00:22:55:9f:fc:a0
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
button pressed for 1 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"...#########################################################################################################################################################################
File "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
Image text-base: 0x00003000, data-base: 0x0035E440
Initializing flashfs...
flashfs[1]: 26 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 6879232
flashfs[1]: Bytes available: 9119744
flashfs[1]: flashfs fsck took 6 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1238Q0HK
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:55:9F:FC:A0
Part Number                          : 73-8962-14
PCA Assembly Number                  : 800-24818-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12354426
Top Assembly Part Number             : 800-29144-03
Top Assembly Serial Number           : FCZ1238Q0HK
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Press RETURN to get started!
*Mar  1 00:00:08.354: %CDP_PD-4-POWER_OK: Full power - AC_ADAPDOWN: Line protocol on Interface FastEthernet0, changed state to up
Press>en
Password:
Password:
Password:
*Mar  1 00:00:27.393: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
% Bad secrets
Press>en
Password:
Password:
Password:
% Bad secrets
Press>
*Mar  1 00:00:36.530: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.2, mask 255.255.255.0, hostname Press
Press>en
Password:
Password:
Press>sho ver
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
Press uptime is 17 minutes
System image file is "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"
Configuration register is 0xF
Press>
Stephen Rodriguez Thu, 07/26/2012 - 06:50
  • Purple, 4500 points or more
The AP you have is running the CAPWAP recovery image.  With the recovery image the only thing the AP will do is try to join a WLC.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Amjad Abdullah Thu, 07/26/2012 - 06:53
you must've been kidding!!
You did not mention that you use a lightweight AP. I was thinking it is a standalone one.
You can reset the default setting for this AP form controller.
Thd default username and password (for telnet and enable) is Cisco (C capital).
If you have changed something from the AP side then this is not supported by Cisco. You should have changed whatever you want from the controller side.
If you have configured a password for the AP from the controller then that is the password. Or you can reset to factory settings. If you don't have a controller and you want the AP to be standalone (autonomous) AP you need to convert it to a standalone mode. Here is a useful link about how to do so:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Amjad
Stephen Rodriguez Thu, 07/26/2012 - 07:26
Amjad,
     The first poster has an IOS AP.  The second poster has a lightweight one.
HTH,
Steve
pgasparovic Thu, 07/26/2012 - 08:14
That's the reason I ended up stuck "in the middle".. Thank you both for reactions and explanation. I'm not any Wifi designer, even not have a plan to do some extra configuration - just wanted to recover some box in our lab here that noone knew what the user/pass could be..  to update it's WAN config a bit - so I had to reset it to defaults. Uff..
Shall I definitevely try that TFTP process, does it work? Because there is a note :
The lightweight 1300 series access points can only be converted back to autonomous mode using a wireless LAN controller.
Please.just confirm this works - and then I will perfom it. Regards
Peter
Stephen Rodriguez Thu, 07/26/2012 - 08:16
yes, the process works.
HTH,
Steve
pgasparovic Fri, 07/27/2012 - 01:11
Yes, performed - IT'S DONE!
Thanks a lot guys for giving me an instant help, otherwise I would get into delay with some customer project, now have 1-2 days to elaborate my stuff. Will know for future, to spread the knowledge
Unfortunately I can't add you portal points with correct answers, just stars.. but I definitely send private msg to guy who opened this to close it. All the question about default  AP passwords are decisively answered here.
Tang-Suan Tan Mon, 07/30/2012 - 00:53
Hi Amjad :
Thanks to your reply!
From your reply and also my trial, I managed to solve this problem.
The trick is the first command :
enable passwork XXXXXX  --> the XXXXX is your Telnet password.
and the second command :
enable secret YYYYYYYY --> the YYYYYYYY is your enable password. You do not need to put 0 to 5 after enable secret.
The two passwords will be encryted automaticaly after these two commands. The enable passward also set to secret 5 automatically.
regards,
tangsuan
Related Content
