In coming voip calls problem
Answered Question
Jul 25th, 2012
Hi Experts
we have 2 branches one with ccum8.6 and another branch  with cme 8.8 both branch are connected with trunk
Cucm ext is 7xxx
cme ext is 5xxx
From 5xxx to 7xxx there no problem in calls but from 7xxx to 5xxx  we are not able to receive calls  but the call hits the 5xxx vg
i here attached the  debug  and the vg configuration
cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7099
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=5019
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jul 25 09:02:51.067: //-1/801949220300/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3127FA60, Call Info(
   Calling Number=7099,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=5019(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=319
Jul 25 09:02:51.067: //-1/801949220300/CCAPI/ccCheckClipClir:
   In: Calling Number=7099(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=7099(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jul 25 09:02:51.067: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 25 09:02:51.067: :cc_get_feature_vsa malloc success
Jul 25 09:02:51.067:  cc_get_feature_vsa count is 1
Jul 25 09:02:51.067: :FEATURE_VSA attributes are: feature_name:0,feature_time:812276736,feature_id:383
Jul 25 09:02:51.067: //319/801949220300/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7099(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=5019(TON=Unknown, NPI=Unknown))
Jul 25 09:02:51.067: //319/801949220300/CCAPI/cc_process_call_setup_ind:
   Event=0x2BD31198
Jul 25 09:02:51.067: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 5019
Jul 25 09:02:51.067: //319/801949220300/CCAPI/ccCallSetContext:
   Context=0x3208C228
   >>>>CCAPI handed cid 319 with tag 1 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Jul 25 09:02:51.067: //319/801949220300/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Jul 25 09:02:51.067: //319/801949220300/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jul 25 09:02:51.067: //319/801949220300/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3127FA60, Tag=0x0, Call Id=319,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jul 25 09:02:51.067: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 25 09:02:51.067: :cc_free_feature_vsa freeing 306A5BF8
Jul 25 09:02:51.067:  vsacount in free is 0
_KSA_CMEVG01#
Please help to resolve the  issue
Correct Answer by acampbell about 5 years 3 weeks ago
Raja,
Lokks to me liker the call is being reject as Toll fraud
Can you allow the calling Ip address under
voice service voip
ip address trusted list
Ipv4 (CALLING IP ADDRESS) 255.255.255.255
Or disable the feature
voice service voip
no ip address trusted authenticate
Alex.
Please rate useful posts.
Overall Rating: 5 (1 ratings)
ronpatel Wed, 07/25/2012 - 03:04
  • Blue, 1500 points or more
Have you specified G729 codec for this call in CUCM. If yes, Please use voice class codec command and add G729 in Dialpeer 1 on CME.
Ronak Patel
rate helpful posts by clicking stars below the answer.
Correct Answer
acampbell Wed, 07/25/2012 - 04:48
  • Green, 3000 points or more
Raja,
voice service voip
voice service voip
Alex.
Related Content
