Warning message
unable to policy switchport interface of CISCO861
Jul 25th, 2012
I'm unable to apply a policing limit in a switchport of the CISCO861 router. This is my configuration:
interface FastEthernet0
service-policy input wired-input
service-policy output wired-output
end
policy-map wired-input
class class-default
   police cir 1000000 bc 187500 be 250000
     conform-action transmit
     exceed-action transmit
     violate-action drop
policy-map wired-output
class class-default
   police cir 2000000 bc 375000 be 500000
     violate-action drop
The switchport uses more than 2/1 Mbps and I don't know why. This port is routed through the WAN interface (Fa4). I must be doing somethig bad...
Thanks in advance,
Christian
Overall Rating: 3 (1 ratings)
cadet alain Wed, 07/25/2012 - 05:13
  • Purple, 4500 points or more
I think you should apply the policy to the WAN interface or the SVI(BVI).
Regards.
Alain.
christian.pinedo Wed, 07/25/2012 - 06:48
I can't apply the service-policy to the SVI Interface, I get an error every time I try it.
And If I apply the service-policy to the WAN interface I don't know if I will be able to apply different policies for private networks because the WAN interface is NATed and I think the source-nat is done before the QoS.
Am I wrong??
Christian
cadet alain Wed, 07/25/2012 - 07:15
if you set dscp for different networks inbound and policeoutbound  according to these dscp values then it should work as NAT is only replacing the src IP address but not the Tos byte to my best knowledge.
Regards.
Alain.
Related Content
