Warning message
pre-provision 2248 TP FEX on 5596UP
Jul 25th, 2012
1. We would like to pre-provision a 2248TP FEX on my 5596UP (NEXUS 5596 running 5.1(3)N2(1a)). Problem is that I can't choose this FEX model. I have the choice of a 2248T or a 2248TP-E, but no 2248TP. What do we need to do ?
sbnswi1# sho fex det
Extender Model: N2K-C2248TP-1GE
sbnswi1(config-slot)# provision ?
  model  Type of the module to be provisioned
sbnswi01(config-slot)# provision model ?
  N2K-B22HP          Fabric Extender 16x10G Module
  N2K-C2148T         Fabric Extender 48x1G 4x10G Module
  N2K-C2232P         Fabric Extender 32x10G Module
  N2K-C2232TM        Fabric Extender 32x10G Module - Zephyr
  N2K-C2248T         Fabric Extender 48x1G 4x10G Module
  N2K-C2248TP-E-1GE  Fabric Extender 48x1G 4x10G Module
  N2K-N2224TP        Fabric Extender 24x1G 2x10G SFP+ Module
2. on pair of NEXUS 5596 running 5.1(3)N2(1a) with a Layer-3 module installed in both.
    When doing Enhanced vPC - connecting all FEXs dual-homed to both 5596 - how  many FEXs can I have in total ?
I found different information in the documentation. Either 8 or 16 ?
Thank you,
Jan
Overall Rating: 4 (1 ratings)
jgeralsky Thu, 07/26/2012 - 08:28
All,
here is the answer from Cisco :
As far as I understand from your case description you are checking which type of FEX should be taken in order to pre-provision your 2248TP chassis. Besides of that you are looking for number of fabric extenders which N5k-C5596 chassis can handle with L3 daughter card installed.
So let’s start with first question. Definitely you are right, at first glance NX-OS gives you not full list of fabric extenders:
dewsbnswi001(config-slot)# provision model ?
Reality is pretty simple here. Keyword N2K-C2248T covers all 48 Tx models except enhanced version (which has 32MB buffer extension). So for your case, this will be right choice.
And here simple example to prove theory above. I do have N2K-C2248TP-1GE which I am pre-provisioning with N2K-C2248T keyword:
TEST_CHASSIS# sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
101        FEX0101                Online     N2K-C2248TP-1GE   JAF1526CELS
TEST_CHASSIS # sh run | egrep -a 1 slot
slot 101
  provision model N2K-C2248T
Regarding to second question I have to admit that with L3 daughter card on board you may have up to 16 fabric extenders (Maximum FEXs dual homed to a vPC switch pair).
Please refer http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration_limits/limits_513/nexus_5000_config_limits_513.html#wp349318 for more information about limits. In fact 8 FEXs limitation was up to 5.0(3)N1(1a). Anyway, your version should support 16 extenders in dual homed config per pair.
Related Content
