Warning message
flow control -- send flow control to be “desired”
Jul 25th, 2012
hi eveyone,
I know about flow control that it is --
flow-control is a mechanics allowing the receiving party of a connection to control the rate of the sending party.
By default flowcontrol is disabled
Need to undertsand line below with example
send flow control to be “desired   what does it mean ?????????
MAhesh
Sandeep Choudhary Thu, 07/26/2012 - 02:45
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Hi Mahesh,
As per my Knowledge:
status to desired (port allows far end to send flow-control packets if far end supports it):
When used with receive, it allows a local port to operate with an attached device that is required to send flow-control packets or with an attached device that is not required to, but may send flow-control packets.
When used with send, the local port sends administrative status to a remote device if the remote device supports it.
Please rate if it helps.
mahesh18 Thu, 07/26/2012 - 07:13
Hi Sandeep,
If we enable this on trunk port
flow control send desired--
i check the switch port
sh int gigabitEthernet 2/1 flowcontrol
Port       Send FlowControl  Receive FlowControl  RxPause TxPause
           admin    oper     admin    oper
Gi2/1      desired  off      desired  on          0       0
so this command tells that flow control for send is desired type right?
I checked on other side of trunk
sh int gigabitEthernet 1/9/2 flowcontrol
Gi1/9/2     desired  on       off      off         0       0
I checked config of this port there was no flow control send desired configured but this still shows send admin desired
do you why?
MAhesh
Related Content
