Warning message
Tunnel Gre
Jul 26th, 2012
We have tunnel gre with wimax (70Mb)  access and other access mpls(30Mb). We configured tunnel gre and we have problem, the tunnels are very slow both.
i show the configuration.
How we change the bandwith of the tunnel???
thanks
nterface Tunnel0
description tunel macrolan
ip address 172.30.17.49 255.255.255.252
ip ospf network point-to-point
ip ospf 1 area 0
keepalive 3 3
tunnel source 172.30.17.35
tunnel destination 10.161.128.6
end
unnel0 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 172.30.17.49/30
  MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 2/255, rxload 17/255
  Encapsulation TUNNEL, loopback not set
  Keepalive set (3 sec), retries 3
  Tunnel source 172.30.17.35, destination 10.161.128.6
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Last input 00:00:09, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d04h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 639
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 7000 bits/sec, 2 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     641353 packets input, 351062214 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     295624 packets output, 148067207 bytes, 0 underruns
     0 unknown protocol drops
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Thu, 07/26/2012 - 11:50
  • Hall of Fame,
    Founding Member
Hello Rafael,
see this thread
https://supportforums.cisco.com/thread/2006803?start=10&tstart=0
it is a question of IOS feature set and to use the appropriate command in interface tunnel configuration
tunnel bandwidth transmit XX
when the command is supported you should be able to put more then 8 Mbps on the tunnel interface
Hope to help
Giuseppe
Rafael Romero Diaz Fri, 07/27/2012 - 03:50
Hi Giuseppe,
We found the commnad in our ios. Thank for your link, has been very useful.
Cheers.
Rafa.
Related Content
