UC520 8.6 & Jabber problem
Jul 26th, 2012
I'm having problems trying to get Cisco Jabber 8.6.5 registered on our UC520.
I used the CCA to add a new Cisco IOS device and in the Jabber configuration screen, I cannot get past the window requesting for SIP digest authentication info.  I keep getting "invalid credentials".
I am currently connected to voice vlan via wireless.
When I run a debug tftp events, I get the following -
Jul 26 20:14:04.833: TFTP: Looking for CTLFile.tlv
Jul 26 20:14:04.849: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 26 20:14:04.849: TFTP: Opened flash:/SEP8C5877646102.cnf.xml, fd 0, size 3419 for process 269
Jul 26 20:14:04.937: TFTP: Finished flash:/SEP8C5877646102.cnf.xml, time 00:00:00 for process 269
Jul 26 20:14:05.001: TFTP: Looking for CUPC/AppDialRules.xml
Jul 26 20:14:05.037: TFTP: Looking for CUPC/DirLookupDialRules.xml
not sure if it helps but
debug voice register events
Jul 26 20:15:07.840: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:07.840: auth absent
Jul 26 20:15:07.840: VOICE_REG_POOL: key(154714E70481E4BF) added to nonce table
Jul 26 20:15:12.136: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:12.136: auth present
Jul 26 20:15:16.556: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:16.556: auth present
Jul 26 20:15:17.388: EVENT: 1 node in nonce tree obsolete
Jul 26 20:15:17.388: VOICE_REG_POOL: deleted key(C4E2344F0481CC53) from nonce table
Jul 26 20:15:18.004: VOICE_REG_POOL: Register request for (217) from (10.1.1.38)
Jul 26 20:15:18.004: auth present
Jul 26 20:15:47.389: EVENT: 1 node in nonce tree obsolete
Jul 26 20:15:47.389: VOICE_REG_POOL: deleted key(5DFE01DE0481DC49) from nonce table
------------------------ here are the configs on my UC520
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server expires max 600 min 60
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register dn  1
number 217
name Test Iphone
no-reg
label 217
voice register global
mode cme
source-address 10.1.1.1 port 5060    <====== this originally had my vlan 1 IP address.  I changed this to vlan 100 IP address
max-dn 224
max-pool 56
load 7971 term71.default
authenticate register
authenticate realm domain.com
hold-alert
voicemail 400
tftp-path flash:
create profile sync 0467524178137408
voice register pool  1
registration-timer max 720 min 660
id mac 8C58.7764.xxxx
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username 217 password 217
codec g711ulaw
Can someone shed some light on my issue?   thanks!
johschaf Thu, 07/26/2012 - 14:33
  • Silver, 250 points or more
Hello jyoopro4ia,
Are you using 217 for the username and password? What type of iPhone are you using, and what version of iOS(Apple's not Cisco's)?
-john
jyoopro4ia Fri, 07/27/2012 - 06:36
john,
yes 217 is username & password.  I'm using Iphone 4 and using iOS 5.1.1
jyoopro4ia Tue, 07/31/2012 - 08:18
John,
Yes I did.  I see that Jabber also requires a license to be purchased.  Will not having the license cause the "invalid credentials" error?  What is the product SKU for the license?
Thank you.
johschaf Tue, 07/31/2012 - 12:13
Hello jyoopro4ia,
Jabber doesn't require a license(other than a normal user license). If you are trying to connect over a VPN, then that requires an ASA with a AnyConnect VPN license. You said that you are trying to register your iPhone locally, correct?
Have you tried just deleting and recreating the phone? Can you post a full debug of the TFTP events while the phone is trying to register?
-john
jyoopro4ia Tue, 07/31/2012 - 12:15
correct.  Locally, not over VPN.  I'll post up the debugs shortly.
jyoopro4ia Tue, 07/31/2012 - 12:35
John,
Should the above IP address be voice vlan IP of phone system or data vlan IP?  just wanted to confirm it should be voice vlan IP.
I am getting this debug info (show debug tftp events)
Jul 31 19:35:02.375: TFTP: Looking for CTLFile.tlv
Jul 31 19:35:02.403: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 31 19:35:02.603: TFTP: Looking for CUPC/AppDialRules.xml
Jul 31 19:35:02.627: TFTP: Looking for CUPC/DirLookupDialRules.xml
and getting Unable to verify account information on the Jabber client.
johschaf Tue, 07/31/2012 - 12:58
Hello jyoopro4ia,
The voice register global source-address is correct, it is the UC's IP on the voice vlan.
As for the debugs:
I wouldn't worry about the CTLFile or CUPC files, those show up in my TFTP debug but they are not on the flash. However, SEP8C5877646102.cnf.xml does matter. Does the TFTP events show that file being opened?
Also, can you post the following:
voice register DN
voice register pool
-john
jyoopro4ia Tue, 07/31/2012 - 13:00
John,
Those 4 lines are the only things I see during debug of tftp events.  Nothing more.  I don't see that file being opened at all.
Please see my original post for the voice register global, register dn and register pool.
johschaf Tue, 07/31/2012 - 13:04
Hello jyoopro4ia,
Hhhhmmm, under telephony-service what is the location of the CNF files? System or flash? If flash, do you see the cnf.xml file in the flash? If not, do a "no create cnf"  and then a "create cnf" and check again.
-john
johschaf Tue, 07/31/2012 - 13:07
Hello jyoopro4ia,
Also, under the voice register global configuration, can you remove the following: "authenticate realm domain.com"
-john
jyoopro4ia Tue, 07/31/2012 - 13:31
John,
It looks like I'm getting further... I checked telephony services and I did not see the following lines in the config -
(the system dates back when UC520 was first released)
cnf-file location: flash:
I added the above line.
Also, I removed "authenticate realm domain.com" from voice register global as well.  I recreated cnf and voice register profile.  When I tried initially to register Jabber, the debugs looked good and showed the phone registered, however it was not able to create a dial-peer due to memory issues (my other discussion that you were assisting me with - https://supportforums.cisco.com/message/3693878#3693878).  Too bad I didn't get to copy this debug output.
Register attempts after the first one looks only like this -
Jul 31 20:29:32.967: TFTP: Looking for CTLFile.tlv
Jul 31 20:29:32.995: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 31 20:29:32.995: TFTP: Opened flash:/SEP8C5877646102.cnf.xml, fd 0, size 3416 for process 269
Jul 31 20:29:33.059: TFTP: Finished flash:/SEP8C5877646102.cnf.xml, time 00:00:00 for process 269
Jul 31 20:29:33.119: TFTP: Looking for CUPC/AppDialRules.xml
Jul 31 20:29:33.151: TFTP: Looking for CUPC/DirLookupDialRules.xml
Although I am still unsuccessful in getting Iphone Jabber registered, I feel like I'm a step closer to resolution.
johschaf Tue, 07/31/2012 - 13:39
Hello jyoopro4ia,
Did the jabber phone register at one point? You said: "When I tried initially to register Jabber, the debugs looked good and showed the phone registered"
Are you still getting the invalid credentials error? If so, can you create a username/password with at least 6 digits, since that is what worked for me in the lab.
-john
jyoopro4ia Tue, 07/31/2012 - 14:01
yes it looked like it was trying to register on my first attempt after making the config changes but I cannot replicate it anymore.  I changed the username & pw to 6 chars (123456 / 123456) and am still getting invalid credentials error.
here is the debug output
Jul 31 21:00:22.154: TFTP: Looking for CTLFile.tlv
Jul 31 21:00:22.182: TFTP: Looking for SEP8C5877646102.cnf.xml
Jul 31 21:00:22.182: TFTP: Opened flash:/SEP8C5877646102.cnf.xml, fd 0, size 3425 for process 269
Jul 31 21:00:22.250: TFTP: Finished flash:/SEP8C5877646102.cnf.xml, time 00:00:00 for process 269
Jul 31 21:00:22.310: TFTP: Looking for CUPC/AppDialRules.xml
Jul 31 21:00:22.350: TFTP: Looking for CUPC/DirLookupDialRules.xml
johschaf Tue, 07/31/2012 - 17:03
Hello jyoopro4ia,
I'd like to confirm a few settings.
1. Internet Calling
  •      Device ID is SEP plus the wireless MAC of the iPhone. You can locate the wireless MAC of the iPhone under General -> About -> Wi-Fi Address
  • TFTP Server is 10.1.1.1
  • Use Authentication is on
  • Username is 123456 and the password is 123456
2. Voicemail
  • Password is 123456
  • Server is 10.1.10.1
  • No port is defined
-john
jyoopro4ia Wed, 08/01/2012 - 08:01
John,
1. Internet Calling
Do you want to confirm the above settings for my Jabber client?  That's exactly how it's setup currently.
2. Voicemail
Are you saying I should be able to log into CUE gui at 10.1.10.1 using 123456 / 123456?
johschaf Wed, 08/01/2012 - 12:16
Hello jyoopro4ia,
I would like for you to just confirm those settings.
I would like for you to run an additional debug when you are trying to register the Jabber client:
debug ccsip messages
Please post or attach that debug out here. This should also us to see the SIP registration and why the UC is not accepting it.
-john
johschaf Wed, 08/01/2012 - 14:01
Hello jyoorpro4ia,
Thanks for providing that debug.
Comparing this to my lab debug, I do see the registration in both cases initially rejected. Then the 2nd registration in my lab works, but fails in your debug with the following error:
Aug  1 19:49:46.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
Via: SIP/2.0/TCP 10.1.1.40:56312;branch=z9hG4bK41b6d8ba
To: ;tag=4BE19CA8-1E96
Date: Wed, 01 Aug 2012 19:49:46 GMT
Call-ID: [email protected]
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 106 REGISTER
Content-Length: 0
Is there anymore configuration under the voice service voip than what was listed above? If I recall correctly, did we remove the bind statements for the MWI issue? If so, I think we need to add those back in for Jabber.
-john
jyoopro4ia Wed, 08/01/2012 - 14:04
This is what I have currently -
voice service voip
sip
  no update-callerid
I removed the bind statements to get my MWI working again.  Does Jabber require these bind statements?  I believe CCA added the bind statements in when I added a Jabber client.
johschaf Wed, 08/01/2012 - 14:19
Hello jyoopro4ia,
Yes, it does seem like Jabber requires those bind statements. Please add the following back to the configuration:
voice service voip
sip
  bind control source-interface Vlan100
  bind media source-interface Vlan100
We might have to change the CUE MWI notification to unsolicited to resolve the MWI issue. Please see your other post regarding MWI for the unsolicted configuraiton.
-john
Related Content
