FCIP Slow Performance
Jul 28th, 2012
Hello - I need some help with fine tuning FCIP between MDS switch to MDS switch.
We have 2 x  cisco MDS 9222i ("4x1GE IPS, 18x1/2/4Gbps FC/Sup2") one at production other at DR.
Both datacentres are connected with dedicated point-to-point with 10 Gbps fibre link. Right now only 5 Gbps bandwidth available.
System version: 5.0(1a)
Ran this command ips measure-rtt x.x.x.x int gigabitethernet 1/3
Round trip time is 12365 micro seconds (12.37 milli seconds)
I have updated following FCIP settings but still not getting over 13 MB/s. Only Single 1 GE is in use right now for performace throughput testing.
Interface              Input (rate is 1 min avg)  Output (rate is 1 min avg)
                       Rate     Total             Rate     Total
                       MB/s     Frames            MB/s     Frames
GigabitEthernet1/3     0        785759219         13       1446349850
FCIP Profile 3
    Tunnels Using this Profile: fcip4
    Listen Port is 3225
    TCP parameters
        SACK is enabled
        PMTU discovery is enabled, reset timeout is 3600 sec
        Keep alive is 60 sec
        Minimum retransmission timeout is 200 ms
        Maximum number of re-transmissions is 4
        Send buffer size is 2000 KB
        Maximum allowed bandwidth is 1000000 kbps
        Minimum available bandwidth is 1000000 kbps
        Configured round trip time is 20000 usec
        Congestion window monitoring is enabled, burst size is 50 KB
        Auto jitter detection is enabled
IP Compression is disabled
TCP Parameters
     Path MTU 9216 bytes
      Current retransmission timeout is 200 ms
      Round trip time: Smoothed 16 ms, Variance: 1 Jitter: 183 us
      Advertized window: Current: 1462 KB, Maximum: 24580 KB, Scale: 10
      Peer receive window: Current: 1429 KB, Maximum: 1429 KB, Scale: 10
      Congestion window: Current: 1286 KB, Slow start threshold: 6925 KB
      Current Send Buffer Size: 3434 KB, Requested Send Buffer Size: 2000 KB
      CWM Burst Size: 50 KB
      Measured RTT : 12306 us Min RTT: 12306 us Max RTT: 12734 us
    5 minutes input rate 626408 bits/sec, 78301 bytes/sec, 869 frames/sec
    5 minutes output rate 118285184 bits/sec, 14785648 bytes/sec, 7807 frames/sec
      92617362 frames input, 8353738592 bytes
         1207649 Class F frames input, 117198804 bytes
         91409713 Class 2/3 frames input, 8236539788 bytes
         0 Reass frames
         0 Error frames timestamp error 0
      1382952749 frames output, 2676072676760 bytes
         1207808 Class F frames output, 161161800 bytes
         1381744941 Class 2/3 frames output, 2675911514960 bytes
         0 Error frames
GigabitEthernet1/3 is up
    MTU 9216  bytes
    Port mode is IPS
    Speed is 1 Gbps
    Beacon is turned off
    Auto-Negotiation is turned on
Sultan
Related Content
Trending Topics: Storage Networking
