Warning message
Clients on 1131AG cannot talk to each other
Jul 28th, 2012
I have a dozen clients on an 1131AG and they cannot ping each other.  I get a reply but it says destination host unreachable.  Any ideas on how to resolve this?  Here is my config:
version 12.4
no service pad
service password-encryption
hostname MediaRoom
no logging console
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip domain lookup
dot11 ssid AJPL Training
authentication open
power inline negotiation prestandard source
username extreme privilege 15 secret 5
username admin privilege 15 password 7
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 A1E447FB3D18 transmit-key
encryption mode wep mandatory
ssid AJPL Training
station-role root
beacon dtim-period 1
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption key 1 size 40bit 7 D71318FE4B24 transmit-key
ssid AJPL Training
dfs band 3 block
channel dfs
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 subscriber-loop-control
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.16.3.15 255.255.255.0
no ip route-cache
ip default-gateway 172.16.3.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779...onfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
banner motd C
* L E G A L N O T I C E -- Y O U M U S T R E A D *
* You must have explicit permission to access or configure this *
* device. All activities performed on this device are monitored *
* and logged. Violations of the *
* security policy may result in criminal prosecution. *
* Anyone using this system expressly consents to such monitoring and is *
* advised that if such monitoring reveals possible evidence of criminal *
* activity, system personnel may provide the evidence of such monitoring *
* to law enforcement officials. *
* UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE IS PROHIBITED *
line con 0
line vty 5 15
end
Overall Rating: 5 (2 ratings)
George Stefanick Sat, 07/28/2012 - 10:30
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Welcome to CSC
I will assume you are authenticated to the access point and this is not an issue. As for the ap, its like a switch. Can you bridge this vlan subnet on the wired and ping the wireless devices? Sounds more like a routing issue to me, but they are on the same subnet. Check the wired side and see if that work first.
Anthony Fitzwater Sat, 07/28/2012 - 10:42
Thanks.
Yes, the clients have authenticated and they are getting the proper network settings via the DHCP server.
From the clients connected wirelessly, I can ping wired clients on the same subnet.
From the clients connected by ethernet, I can ping the wireless clients on the same subnet.
I just can't get the wireless clients to talk to each other.
I plugged in a Linksys WAP54G and connected the wireless clients to it and they can communicate fine, so I assume there is something in the config (or something not in the config) that is preventing them from communicating with each other.
Rob Huffman Tue, 07/31/2012 - 06:16
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Anthony,
Just to add a note to the great tips from my friends George and Amjad (+5 )
I might try this doc as well;
https://supportforums.cisco.com/docs/DOC-4823
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Related Content
