Replacing routing function with a switch
Answered Question
Jul 28th, 2012
I have the task of replicating the router config on a 3825 router on a 3750 switch. Reason is we are taking out the router and replacing it with the switch to make use of the router for other functions.
Below is main part of the router config:
ip source-route
ip cef
license udi pid CISCO3825 sn FCZxxxxxxx
vlan internal allocation policy ascending
interface GigabitEthernet0/0
ip address 10.19.28.5 255.255.255.0
duplex auto
speed 100
media-type rj45
no mop enabled
interface GigabitEthernet0/1
ip address 10.19.127.16 255.255.255.0
duplex auto
speed auto
media-type rj45
interface FastEthernet1/0
description "m2_s17"
switchport access vlan 2
speed 100
no cdp enable
interface FastEthernet1/1
description "m2_s19"
switchport access vlan 3
speed 100
no cdp enable
interface FastEthernet1/2
description "m2_s21"
switchport access vlan 4
speed 100
no cdp enable
interface FastEthernet1/3
description "m2_s23"
switchport access vlan 5
speed 100
no cdp enable
interface FastEthernet1/4-14
shutdown
interface FastEthernet1/15
no switchport
ip address 10.19.128.16 255.255.255.0
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.61.1 255.255.255.252
ip load-sharing per-packet
ip ospf priority 10
interface Vlan3
ip address 192.168.61.5 255.255.255.252
ip ospf priority 10
interface Vlan4
ip address 192.168.61.9 255.255.255.252
ip ospf priority 10
interface Vlan5
ip address 192.168.61.13 255.255.255.252
ip ospf priority 10
router ospf 100
log-adjacency-changes
area 0.0.0.4 stub
network 192.168.61.0 0.0.0.3 area 0.0.0.4
network 192.168.61.4 0.0.0.3 area 0.0.0.4
network 192.168.61.8 0.0.0.3 area 0.0.0.4
network 192.168.61.12 0.0.0.3 area 0.0.0.4
ip default-gateway 10.19.28.254
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 10.19.28.254
scheduler allocate 20000 1000
end
The 3750 switch I have runs C3750E-UNIVERSALK9-M, Version 12.2(55)SE3 on a LAN BASE license.
The first thing I have done is to order for a license upgrade to IP BASE which would give the support for OSPF routing.
I do not see much of an issue with the Interface configs, however, I am not too sure about replicating the routing config on the switch.
My question is can I run the commands as shown for the OSPF routing on the switch? If not, can I get suggestions on how best to set this up on the switch?
Femi
Correct Answer by adfsdafs adsfafds about 4 years 11 months ago
The IP Base image supports OSPF for routed access to enable customers to extend Layer 3 routing capabilities to the access or wiring closet. The IP services image is required if you need multiple OSPFv2 and OSPFv3 instances without route restrictions. (Catalyst 3750 and 3560).
source: http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/release/notes/OL23054.html
I didn't know there was a LAN base licence for 3750. I don't see it in software download.
Overall Rating: 5 (1 ratings)
Reza Sharifi Sat, 07/28/2012 - 15:44
  • Cisco Designated VIP,
    2017 LAN
If you are planning to deploy OSPF I suggest you use IP Service license instead of IP Base as there are limitation with IP base
Other than that you can deploy OSPF on your switch just like the router
Also be aware that the switch does not run NAT, IPSec, if you need them
femi.agboade Sat, 07/28/2012 - 15:52
Hello Reza,
Thanks for the response.
The IP Service license is actually quite pricey compared to the IP Base, more so that we arent doing any complex type of routing, not different from what is displayed in the router config I stated above.
I had also checked the Cisco configuration tool and noticed that both IP Base and IP Services license had pretty much the same feature set as regards OSPF functions.
So do you think I can run the setup below on the IP Base license:
interface Vlan4
ip ospf priority 10
router ospf 100
area 0.0.0.4 stub
Femi
Correct Answer
adfsdafs adsfafds Sun, 07/29/2012 - 12:15
femi.agboade Sun, 07/29/2012 - 14:26
Thank you for your comments and the reference link.
We purchased the 3750 switches with the LAN base license which I think is the default license that comes with the switch when it is purchased.
Femi
Related Content
