07-28-2012 07:54 AM - edited 02-21-2020 10:27 AM
I configured the ff. commands on my router:
R1(config)# aaa new-model
R1(config)# tacacs-server host 172.16.178.3 key xxxxxx
R1(config)# ip tacacs source-int fa0/1
R1(config)# aaa authentication login forCONSOLE group tacacs
R1(config)# aaa authorization console
R1(config)# aaa authorization config-commands
R1(config)# aaa authorization commands 15 forCONSOLE group tacacs
R1(config)# line con 0
R1(config-line)# login authentication forCONSOLE
R1(config-line)# authorization commands 15 forCONSOLE
What is the used of number "15"? Does it mean privilege level 15? if so, why is that when login through my router i got an error "command authorization failed" for "configure terminal" command?
Solved! Go to Solution.
07-31-2012 12:37 AM
i think you can find your answers in this document:
Tariq
07-28-2012 08:42 AM
You are configuring per command authorization with tacacs.
Have you specified command authorization set that make sure to permit the config terminal command for the login user?
Tariq
Sent from Cisco Technical Support Android App
07-28-2012 09:06 AM
Thanks Tariq,
So you mean that per level say from 0 to 15 has different set of commands? example
level 0: has a command set > enable / call / exit
level 1: enable / conf
level 2:
because on each levels we can modify the commands using "privilege exec level" command. HOw to specify a command authorization set? Am i going to set it in the acs server? or in the local router using the "privilege exec level" command. Can you show me the step by step procedure on how to do this? becaue i'm new to this.
07-31-2012 12:37 AM
Tariq
