Warning message
PIX PDM
Jul 29th, 2012
im sort of at my wits end, ive spent most of the after noon trying to work this out - I got hold of an old pix 501, running following:
Hardware:   PIX-501, 16 MB RAM, CPU Am5x86 133 MHz
Flash E28F640J3 @ 0x3000000, 8MB
BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 001d.4521.a06f, irq 9
1: ethernet1: address is 001d.4521.a070, irq 10
Licensed Features:
Failover:                    Disabled
VPN-DES:                     Enabled
VPN-3DES-AES:                Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces:          2
Cut-through Proxy:           Enabled
Guards:                      Enabled
URL-filtering:               Enabled
Inside Hosts:                10
Throughput:                  Unlimited
IKE peers:                   10
This PIX has a Restricted (R) license.
Serial Number: 907381129 (0x36158989)
Running Activation Key: 0x6e9eef0d 0x39fc65c5 0x12491b66 0x1be8afaf
Configuration has not been modified since last system restart.
192.168.1.1#
Everytime i try and start the PDM, i get the error that there is a hostname mismatch with certificates.
Now i've tried the following:
1) 5 differant versions of java, from 1.5 and under.
2) Tried delating the key on the router and re-createing it.
Ive been all over the internet checking out lots of other people who had this problem and it seems to relate to java or the cetificates, but i still cant get this working...has anyone got any suggestions ?
Im not a company so dont have a CCO login to maybe uprage the IOS and PDM...I'm more than happy to try and configure things via command line...i just cant stand it when i cant work out why its not working.....
Ramraj Sivagnan... Sun, 07/29/2012 - 20:56
  • Silver, 250 points or more
Hi Bro
As long as your config looks like this, this is not a FW problem. Perhaps, it could be your PC. Have you tried with another PC, to see if this works fine? I suspect this has something to do with your browser's cookies etc.
asdm image flash:/asdm
asdm history enable
http server enable
http 10.0.0.0 255.0.0.0 inside
domain-name cisco.com
hostname FW01
Try this as well;
ca zeroize rsa
ca generate rsa key 768 <-- 1024 and above seems to have compatiblity issue with some browsers.
ca save all
Karsten Iwen Sun, 07/29/2012 - 23:28
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
The error-message in question comes when you connect to your pix with a different hostname then what is in the certificate. If you only have the IP-address in the certificate, then you have to use https://1.2.3.4. If you have used a hostname or FQDN, then you have to use that: https://pixfirewall or https://pixfirewall.yourdomain.local. Just change the IP or the names to what you have on your PIX. If you have a name in your certificate you also need to make sure that the name resolves to the correct IP-address.
If you don't know what's in the certificate, I think the command on this plattform was also "show crypto ca certificate". There you need to look at the field "subject".
Related Content
