CSCtg00438 - Need a way to syslog per-class COPP drops based on thresholds
Jul 30th, 2012
I know that the bug is fixed, but when I´m trying to configure the CoPP-Logging stuff under NX-OS 5.2(5) I do not see any kind of logs even if the policy is already dropping the traffic.
Config is:
policy-map type control-plane copp-system-policy
   class copp-system-class-exception
      logging drop threshold 39600000 level 5
regards,
    Dirk
Overall Rating: 5 (1 ratings)
Phillip Remaker Mon, 07/30/2012 - 10:09
  • Cisco Employee,
The bug id you mention added the CLI, so if the CLI is accepted you already have the patch.  However, there may be some other issue, whether it is a new bug of a configuration error in logging.  It would be best to ask the question in another forum (or oprn a TAC case), since this is either a configuration issue or a new bug.
Dirk Woellhaf Mon, 08/06/2012 - 23:25
it seems that since 5.2.x, the default-policies are "read-only" so you have to copy the policy and then add the logging-stuff.
Will try it and provide some feedback.
regards,
    Dirk
Dirk Woellhaf Thu, 08/16/2012 - 08:32
After copying to policy and modifying it everything works as expected!
Related Content
