Warning message
Cat 2960 shows mac address port as "Drop"
Jul 30th, 2012
Hi all
I am configuring a Cat 2960 port for connecting a VOIP phone, authenticated by MAB.  On connecting the phone, I get the port authenticated and assigned to the correct VLAN, with LLDP-MED advertising the correct voice vlan.  However, I then see no traffic from the phone on the switch.  I can see the MAC address of the phone is learned in the right VLANs, but the mac address is showing as "Drop", which normally means the address is statically configured to be blocked.  There is no static mac address table blocking configured on the switch.   Can anyone suggest why this is happening?
Switch Version
Switch Ports Model              SW Version            SW Image
*    1 50    WS-C2960-48TC-L    15.0(1)SE3            C2960-LANBASEK9-M
Port configuration
interface FastEthernet0/1
description "Standard user port"
switchport access vlan 9
switchport mode access
network-policy 1
no logging event link-status
srr-queue bandwidth share 5 10 40 55
priority-queue out
authentication host-mode multi-auth
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication timer reauthenticate server
mab eap
mls qos trust dscp
no snmp trap link-status
macro description vanilla_port
dot1x pae authenticator
dot1x timeout tx-period 3
dot1x timeout supp-timeout 3
spanning-tree portfast
end
LLDP-MED network-policy
network-policy profile 1
voice vlan 835
Authentication (debug radius) result
Jul 30 11:42:19.600: %AUTHMGR-5-START: Starting 'mab' for client (0004.f297.6668) on Interface Fa0/1 AuditSessionID 0AF0042200000063616A0592
Jul 30 11:42:19.650: %MAB-5-SUCCESS: Authentication successful for client (0004.f297.6668) on Interface Fa0/1 AuditSessionID 0AF0042200000063616A0592
Jul 30 11:42:19.650: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (0004.f297.6668) on Interface Fa0/1 AuditSessionID 0AF0042200000063616A0592
Jul 30 11:42:20.682: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (0004.f297.6668) on Interface Fa0/1 AuditSessionID 0AF0042200000063616A0592
Resulting Switchport config - voice vlan is 835
CLBdg640Test-AS2960-0#show int fa0/1 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 9 (NATIVE-DISCARD)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 835 (VOICE)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
LLDP neighbor info showing voice vlan 835
CLBdg640Test-AS2960-0#sh lldp neighbors fa0/1 detail
Chassis id: 0.0.0.0
Port id: 0004.f297.6668
Port Description - not advertised
System Name - not advertised
System Description - not advertised
Time remaining: 3558 seconds
System Capabilities: T
Enabled Capabilities: T
Management Addresses - not advertised
Auto Negotiation - supported, enabled
Physical media capabilities:
    100base-T2(HD)
    100base-TX(FD)
    100base-T4
    10base-T(FD)
Media Attachment Unit type - not advertised
Vlan ID: - not advertised
MED Information:
    MED Codes:
          (NP) Network Policy, (LI) Location Identification
          (PS) Power Source Entity, (PD) Power Device
          (IN) Inventory
    Inventory information - not advertised
    Capabilities: NP
    Device type: Endpoint Class III
    Network Policy(Voice): VLAN 835, tagged, Layer-2 priority: 5, DSCP: 46
    PD device, Power source: PSE, Power Priority: High, Wattage: 6.5
    Location - not advertised
Total entries displayed: 1
MAC address table showing "Drop" port for learned address in VLAN 835
CLBdg640Test-AS2960-0#sh mac address-table address 0004.f297.6668
          Mac Address Table
Vlan    Mac Address       Type        Ports
   9    0004.f297.6668    STATIC      Fa0/1
835    0004.f297.6668    DYNAMIC     Drop
Total Mac Addresses for this criterion: 2
Overall Rating: 5 (1 ratings)
raarons Mon, 07/30/2012 - 06:29
Found the problem.  Needed to send the Cisco VSA "device-traffic-class=voice" via Radius.
Ditmar Tavares Wed, 04/08/2015 - 08:10
I am having this issue, could you share how you configured this solutions ?
kgalaxy Tue, 10/15/2013 - 23:06
Thanks for updating the problem raarons!
