MM Fiber to MM Fiber
Jul 30th, 2012
I have 4 different fiber network feeds coming in from different buildings / closet into a room.. from that room a 24 strand fiber runs to the datacenter.
All the fiber is MM 62.5.
So lets say I want to run patch cables from each of the fiber patch panels to this 24 strand fiber and bypass using a switch in the closet all together.
Is this possible?
So for Building A it would look like this...
Building A: 6 strands to fiber patch panel -> Miscellaneous Building Closet Fiber Jumper -> 6 strands to fiber patch panel in Datacenter
Vincenzo Errante Mon, 07/30/2012 - 13:33
Let's see if I understand....
you want to go from X building to datacentent with passive F.O. connectivity by patching step by step?
If I understand correctly... you do consider the total distance together with the sfp or gbic that you will use.
nkarthikeyan Tue, 07/31/2012 - 06:45
  • Gold, 750 points or more
Hi Jensen,
Do you mean to say that from buliding to data centre you will be putting a switch in between to extend the fiber connectivity all the way through datacentre????
By
Karthik
Vincenzo Errante Tue, 07/31/2012 - 07:43
You can do it without the switch, but it depends on the total distance and the type of  connectivity, you will use data.
what kind of connectivity would you use? 1gb sx?
Alessio Andreoli Thu, 08/02/2012 - 07:02
  • Silver, 250 points or more
Hi Jensen,
don't use any switch in the middle. Just patch from one patch panel location building_A_incoming_fiber to the corresponding outgoing patch panel location Datacentre_fiber_out . Often these operations are referred as "loop" because you do not terminate the fiber on an active device but you loop it back to another fiber. As above mentioned, if your patch panel is passive (does not refresh the signal) you need to count the total distance and to compare to the type of MM fiber you are using .
good Luck
Alessio
Related Content
