Can not enable ipv6 unicasting
Answered Question
Jul 31st, 2012
I have cisco catalyst Model WS-C3560X-48, SW Version 15.0(1)SE2, SW Image C3560E-UNIVERSALK9-M
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3560X-48       15.0(1)SE2            C3560E-UNIVERSALK9-M
I want to enable ipv6 but I can't
Switch(config)#ip?
ip  ipc
I search on cisco Feature Navigator it tell that this image can support ipv6.
Correct Answer by Andre Albuquerque about 5 years 2 weeks ago
Overall Rating: 5 (1 ratings)
Ivan Krimmel Tue, 07/31/2012 - 06:36
  • Gold, 750 points or more
Have you enabled 'ipv6 unicast-routing' enabled in the global config mode?
Eakapong Gomonsing Wed, 08/01/2012 - 00:11
Thank you for your reply and I can not open the link because of Forbidden.
I type the command ipv6 unicasting but it can not.
Eakapong Gomonsing Tue, 08/07/2012 - 01:05
Wonderful, after i configure command
Switch(config)#sdm prefer dual-ipv4-and-ipv6 default
i can use IPv6 features.
Thank, Andre.
jstuxuhu0816 Tue, 08/07/2012 - 08:15
Why we need to configure this command for the switch?
Any special reason?
