Getting IPv6 working on cable networks
Jul 31st, 2012
Looking to get a router in my lab working on a comcast cable modem.  I am recieving RAs from the ISP router, however my router will not generate its global unicast from the prefixes, regardless of ipv6 address autoconfig
General config:
ipv6 unicast-routing
ipv6 cef
ipv6 multicast-routing
Interface config:
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip nat outside
ip inspect WANInbound in
ip virtual-reassembly
duplex auto
speed auto
ipv6 address autoconfig default
ipv6 enable
ipv6 nd ra suppress
Debug output:
1w3d: ICMPv6-ND: Received RA from FE80::201:5CFF:FE23:A441 on FastEthernet0/0
Show Output:
UC520#show ipv6 routers
Router FE80::201:5CFF:FE23:A441 on FastEthernet0/0, last update 0 min
  Hops 0, Lifetime 1800 sec, AddrFlag=1, OtherFlag=1
  HomeAgentFlag=0, Preference=Medium
  Reachable time 30000 msec, Retransmit time 1000 msec
  Prefix 2001:558:4020:2F::/64
    Valid lifetime 604800, preferred lifetime 302400
  Prefix 2001:558:6007:2E::/64
UC520#
In addition, if a computer is plugged directly into the cable modem, it picks up an IPv6 address no problem, and it works wonderfully.
Any ideas?
C
Marcin Latosiewicz Thu, 08/02/2012 - 06:41
  • Cisco Employee,
hey Cale,
Can you post
debug ipv6 icmp
debug ipv6 nd
show ipv6 int
My config:
interface FastEthernet8
ip address 10.2.2.1 255.255.255.0
duplex auto
speed auto
ipv6 enable
ipv6 nd ra suppress
crypto ipsec client ezvpn EZ
Debugs:
bsns-892-2#sh ipv6 routers
Router FE80::32E4:DBFF:FEB3:B924 on FastEthernet8, last update 0 min
  Hops 64, Lifetime 1800 sec, AddrFlag=0, OtherFlag=0, MTU=1500
  Reachable time 0 (unspecified), Retransmit time 0 (unspecified)
  Prefix 2001:DB8::/64 onlink autoconfig
    Valid lifetime 2592000, preferred lifetime 604800
bsns-892-2#
bsns-892-2#
bsns-892-2#
*Aug  2 13:34:30.083: ICMPv6: Received R-Advert, Src=FE80::32E4:DBFF:FEB3:B924, Dst=FF02::1
*Aug  2 13:34:30.083: ICMPv6-ND: Received RA from FE80::32E4:DBFF:FEB3:B924 on FastEthernet8
*Aug  2 13:34:30.083: ICMPv6-ND: Prefix : 2001:DB8::, Length: 64, Vld Lifetime: 2592000, Prf Lifetime: 604800, PI Flags: C0
*Aug  2 13:34:30.083: ICMPv6-ND: Update on-link prefix 2001:DB8::/64 on FastEthernet8/FE80::32E4:DBFF:FEB3:B924, lifetime 2592000
*Aug  2 13:34:30.083: ICMPv6-ND: %FastEthernet8: OK: IPv6 Address Autoconfig 2001:DB8::/64 eui-64, 2001:DB8::32E4:DBFF:FEB3:B8E2 2001:DB8::32E4:DBFF:FEB3:B8E2/64 is existing
this leads to:
bsns-892-2#sh ipv6 interface fa8
FastEthernet8 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::32E4:DBFF:FEB3:B8E2
  No Virtual link-local address(es):
  Stateless address autoconfig enabled
  Global unicast address(es):
    2001:DB8::32E4:DBFF:FEB3:B8E2, subnet is 2001:DB8::/64 [EUI/CAL/PRE]
      valid lifetime 2591988 preferred lifetime 604788
  Joined group address(es):
    FF02::1
    FF02::1:FFB3:B8E2
  MTU is 1500 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  ND DAD is enabled, number of DAD attempts: 1
  ND reachable time is 30000 milliseconds (using 30000)
  ND NS retransmit interval is 1000 milliseconds
  Default router is FE80::32E4:DBFF:FEB3:B924 on FastEthernet8
Tested on 15.2(3)T on 892 router.
M.
calejaycolony Thu, 08/02/2012 - 21:46
The debugs:
1w6d: ICMPv6: Received R-Advert, Src=FE80::201:5CFF:FE23:A441, Dst=FF02::1
1w6d: ICMPv6-ND: Received RA from FE80::201:5CFF:FE23:A441 on FastEthernet0/0
The show:
UC520#show ipv6 interface fastEthernet 0/0
FastEthernet0/0 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::21E:13FF:FE27:4456
  Description: $FW_OUTSIDE$
  General-prefix in use for addressing
  No global unicast address is configured
    FF02::1
    FF02::2
    FF02::D
    FF02::16
    FF02::1:FF27:4456
  MTU is 1500 bytes
  ND reachable time is 30000 milliseconds (using 25242)
  Hosts use stateless autoconfig for addresses.
UC520#show ipv6 neighbors
IPv6 Address                              Age Link-layer Addr State Interface
FE80::201:5CFF:FE23:A441                    3 0001.5c23.a441  STALE Fa0/0
On the readdition of ipv6 address autoconfig default to the interface:
1w6d: IPv6-Address: Adding operating owner autoconfigured on FastEthernet0/0
1w6d: ICMPv6-ND: Selected new default router FE80::201:5CFF:FE23:A441 on FastEthernet0/0
1w6d: IPv6RT[Default]: static, Route add ::/0 [owner]
1w6d: IPv6RT[Default]: static, Adding next-hop FE80::201:5CFF:FE23:A441 over FastEthernet0/0 for ::/0, [1/0]
1w6d: ICMPv6-ND: Installed default to FE80::201:5CFF:FE23:A441 on FastEthernet0/0
1w6d: IPv6RT[Default]: Event: ::/0, Path, owner static, previous None
1w6d: ICMPv6-ND: O bit set; checking stateless DHCP
Results in:
UC520#show ipv6 address
IPv6 Address Database for Table Default
Code: * - administratively active
IPv6 Routing Table - Default - 3 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
       M - MIPv6, R - RIP
S   ::/0 [1/0]
     via 2601:4:2CC0:40:201:5CFF:FE23:A441
     via FE80::201:5CFF:FE23:A441, FastEthernet0/0
S   2601:4:2CC0:40::/64 [1/0]
     via Null0, directly connected
L   FF00::/8 [0/0]
     via Null0, receive
Thanks for your input!
calejaycolony Thu, 08/02/2012 - 21:56
Also,
Marcin Latosiewicz Fri, 08/03/2012 - 01:16
  • Cisco Employee,
Heh. That's interesting:
Unicast route to null0 ....
What SW version is this?
With the two debugs I mentioned above I would have expected way more info displayed - maybe you need to let it run a bit longer or do an upgrade to something more recent?
M.
calejaycolony Fri, 08/03/2012 - 01:21
UC520#show ver
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Jul-08 08:44 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
UC520 uptime is 1 week, 6 days, 8 hours, 55 minutes
System restarted at 19:24:01 EDT Fri Jul 20 2012
System image file is "flash:/uc500-advipservicesk9-mz.124-20.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco UC520W-8U-4FXO-K9 (MPC8358) processor (revision 0x202) with 249856K/12288K bytes of memory.
Processor board ID FTX1219Z029
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
14 User Licenses
10 FastEthernet interfaces
2 terminal lines
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
UC520#
Marcin Latosiewicz Fri, 08/03/2012 - 01:26
  • Cisco Employee,
Come on, have mercy! 12.4(20)T?
I would say (if you can) give it a try with 12.4(24)T-latest
and post show tech/running config.
But if you want to get it done faster - TAC case.
calejaycolony Fri, 08/03/2012 - 01:34
No contract, old equipment. Bummer I guess.. Will post a scrubbed config.
ROBERTO TACCON Thu, 08/02/2012 - 07:27
Have you try to remove the inspection and check if it works ...
calejaycolony Thu, 08/02/2012 - 21:53
I may be mistaken, but the ip inspection engine is seperate from ipv6 inspect.  IP inspect would only process packets if the ethertype is 0x0800, not 0x86DD.  Also, the router is recieving the RAs as noted in the OP.
On the likely hood I was mistaken, I removed it to no avail.
Thanks for the post though!
Andrew Yourtchenko Tue, 08/21/2012 - 13:48
  • Cisco Employee,
AddrFlag=1 means the sender sets managed config flag thus they want you to use DHCPv6, not SLAAC. The behavior is correct. If you configure your CPE router to run DHCP-PD client to populate a general prefix, you can use that general prefix for LAN facing interface and then use it to do SLAAC for your clients. IIRC they delegate a single /64 via PD by default, but you could ask for more.
Spoiler: http://www.dslreports.com/forum/remark,27192895 has the config
See if this helps.
Maybe counterintuitively to v4 wisdom, you do not really need the global address outside to route - the next hops are link locals.
calejaycolony Tue, 08/21/2012 - 18:52
It was an incomplete implementation in the iOS build. Ended up using a 1941w upgraded to 1.4 and it worked like a charm, although I needed to activate the data eval license to enable the dhcp client pd command on the wan interface. Frustrated that you need to purchase high end feature licenses to emulate the functionality of consumer grade equipment at available at Walmart, but such is Cisco I guess...
Thanks again though!
