Reseting Password for 7604 Router
sly007
I have tried to reset the password for 7604 but it is not working.
At the rommon mode, i input 0x2142, and then reset.
It reloads and keeps asking for password.
Please help
Please take the time to read ALL the document that I've  linked before, to the part that says:
The boot sequence is different on the Catalyst 6500/6000 and Cisco 7600 that run Cisco IOS System Software than the Cisco 7200 Series Router because the hardware is different. After you power-cycle the box, the switch processor (SP) boots up first. After a short amount of time (approximately 25 to 60 seconds) it transfers console ownership to the route processor (RP (MSFC)). The RP continues to load the bundled software image. It is crucial that you press Ctrl-brk just after the SP gives over control of the console to the RP. If you send the break sequence too soon, you end up in the ROMMON of the SP, which is not where you should be. Send the break sequence after you see this message on the console:
00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor
After this point, the password recovery is the same as a normal router.
7 Replies 7
paolo bevilacqua
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot executing command: "boot bootdisk:s72033-ipservices_wan-mz.122-33.SXH8b
.bin"
Loading image, please wait ...
Initializing ATA monitor library...
Self extracting the image... [OK]
Self decompressing the image : #################################################
############################# [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-IPSERVICES_WAN-M), Version 12.
2(33)SXH8b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 14-Sep-11 12:31 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x41C6F330
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging out
put.
00:00:05: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
00:00:09: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging
output.
00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure consol
e debugging output.
Firmware compiled 13-Aug-10 11:12 by integ Build [100]
00:00:09: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 1048576 Kbytes of main memory
Download Start
Download Completed! Booting the image.
           cisco Systems, Inc.
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.
Compiled Wed 14-Sep-11 12:26 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x42C30090
cisco CISCO7604 (R7000) processor (revision 2.0) with 983008K/65536K bytes of me
mory.
Processor board ID FOX1516G2U9
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
72 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Press RETURN to get started!
User Access Verification
Username:
Flowmask is MODIFIED to interface and full flow
% Username:  timeout expired!
And where is the confreg setting part ?
Forgive me, it was omitted,
Here is the full log:
monitor: command "boot" aborted due to user interrupt
Exit at the end of BOOT string
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 > confreg 0x2142
rommon 2 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
BOOT=bootdisk:s72033-ipservices_wan-mz.122-33.SXH8b.bin,1;
RET_2_RTS=20:37:36 UTC Tue May 22 2012
SLOTCACHE=cards;
TYFIB_BLOCK_ALLOC=
NT_K=0:0:0:0
BSI=0
RET_2_RCALTS=
ACL_DENY=0
PF_REDUN_CRASH_COUNT=0
RANDOM_NUM=1126521762
?=0
rommon 3 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 4 > set
PS1=rommon ! >
SLOTCACHE=cards;
TYFIB_BLOCK_ALLOC=
NT_K=0:0:0:0
BSI=0
RET_2_RCALTS=
ACL_DENY=0
?=0
rommon 5 > confreg 0x2142
rommon 6 > set
PS1=rommon ! >
SLOTCACHE=cards;
TYFIB_BLOCK_ALLOC=
NT_K=0:0:0:0
BSI=0
RET_2_RCALTS=
ACL_DENY=0
?=0
rommon 7 > reset
.bin"
           cisco Systems, Inc.
put.
output.
e debugging output.
Download Start
           cisco Systems, Inc.
mory.
Username:
THANK YOU SOOOOOOOOOOOO MUCHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
IT WORKED ! ! ! ! ! .
Thank you, once again.
Thank you for the nice rating and good luck!
