Configure Replace (How to remove vlans ? )
EvaldasOu
Level 4
Level 4
Hello guys.
As you know we can remove vlans without reload, just with the command "no vlan 1-4094. For example:
SW1(config)#vlan 15
SW1(config-vlan)#no vlan 1-4094
%Default VLAN 1 may not be deleted.
%Default VLAN 1002 may not be deleted.
%Default VLAN 1003 may not be deleted.
%Default VLAN 1004 may not be deleted.
%Default VLAN 1005 may not be deleted.
SW1(config)#do sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gi0/1, Gi0/2
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
As you can see VLAN15 was succesfully removed!
There is good command to clear our device configuration. #configure replace dir:filename.cfg
Take a look what happens when we wan't to remove VLANs. Our new configuration ( we will replace running config with this):
SW1#more flash:config.cfg
version 15.0
no service pad
service timestamps debug datetime localtime
service timestamps log datetime msec localtime
service timestamps log uptime
hostname SW1
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
clock timezone GMT+2 2
clock summer-time GMT+2 recurring last Sun Mar 2:00 last Sun Oct 3:00
system mtu routing 1500
ip subnet-zero
vtp mode transparent
no vlan 2-1000
end
When we run "configure replace" command:
SW1#configure replace flash:config.cfg list force
% Default interface VLAN 1 may not be deleted.
00:07:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Rollback aborted after 5 passes
The following commands are failed to apply to the IOS image.
no interface Vlan1
Mhm, VLAN 1 may not be deleted? That's ok. But why VLAN15 is still there?
SW1#sh vlan
                                                Gi0/1, Gi0/2
15   VLAN0015                         active
Is it possible to use configure replace command and succesfully remove VLANs? Which command I am missing in my new configuration file?
Thank you very much for your time and your help!
6 Replies 6
yjdabear
Does vlan15 show up in the output of "show archive config differences flash:config.cfg running-config"?
Hello yjdabear!
No there is no difference related with vlans. I can see just my new commands :
+vtp mode transparent
+no vlan 2-1000
This is also interesting. I can't remove VLANs with TCL script too, please take a look guys:
Switch(tcl)#puts [open "flash:no_vlan.tcl" w+] {
+>puts [ios_config "no vlan 1-4094" "end"]
Switch(tcl)#tclquit
Switch#sh vlan
                                                Gi0/1, Gi0/2
10   VLAN0010                         active
1003 token-ring-default               act/unsup
1005 trnet-default                    act/unsup
Switch#tclsh flash:no_vlan.tcl
Switch#sh vlan
                                                Gi0/1, Gi0/2
10   VLAN0010                         active
Still no ideas ?
According the documentation, "configure replace" applies the same algorithm as "show archive config differences flash:config.cfg running-config" so if vlan 15 is not seen in the latter's diff output, the former won't replace it either.
The reason vlan 15 cannot be replaced is probably because of vlan.dat, depending on the mode of your device (vtp server, client or transparent).
Nico48
I fixed it on my old 3500XL:
SW01#vlan database
SW01#no vlan 2
SW01(vlan)#exit
APPLY completed.
Exiting....
SW01#sh vlan
