LMS 4.2 maximum records in syslog report is 10,000
Aug 1st, 2012
LMS 4.2.1 W2K8 R2
I seem to be unable to generate a syslog report that contains > 10,000 records.  And I don't mean with run type immediate either.  I am scheduling them to run at the next 5 minute interval (incidentally, why not have an option that just says "run in background now"?  But I digress....)
I am facing an issue where a bunch of errors are being generated by a voice gateway and I want to determine when the problem started.  My syslog contains 7 days of records.  If I schedule a report to give me all syslog records for the last 1 week (or 7 days I have tried it both ways) for all devices at that location I get 10,000 records, and they are all for the current date.  If I schedule a report and select a date range in the past, I get records within that date range, but only 10,000.
Has anyone else run into this?
-Jeff
Martin Ermel Fri, 08/10/2012 - 09:13
  • Blue, 1500 points or more
I think this should change what you want - if not, revert it to the default:
for security, make a backup of the following file and open it in a text editor:
NMSROOT\MDC\tomcat\webapps\rme\WEB-INF\classes\com\cisco\nm\rmeng\csc\data\Collector.properties
change the following to a value that might fit your needs but be careful this can affect system performance:
    QUEUE_CAPACITY=100000
save the file and restart the following syslog processes:
in a DOS box check the status of the following processes (they should be started) and restart them:
    pdshow SyslogAnalyzer SyslogCollector
    pdterm SyslogAnalyzer SyslogCollector
    pdexec SyslogAnalyzer SyslogCollector
now, try to re-run your report.
jedavis Fri, 08/10/2012 - 09:42
Thanks for the suggestion Martin.  I tried changing it from 100,000 to 1,000,000 and it had no effect.  Still have a 10,000 record limit in the syslog reports.
I have a TAC case open on this.
Related Content
