Setting up guest WLANs with landing page
Answered Question
Aug 2nd, 2012
hi there,
I've been asked to create 2 wireless networks for guest access. They are to be used by clients of 2 different companies and they have asked for the website of each company to automatically open as a landing page. e.g.
WLAN1 - password is companyname1 - landing page = www.companyname1.com
WLAN2 - password is companyname2 - landing page = www.companyname2.com
Is this possible with our 5508 WLC? I have googled it and can see that you can set a web auth page but I need different landing pages depending on which WLAN is connected to.
Hope this makes sense - TIA for any advice.
Al
Correct Answer by Scott Fella about 4 years 11 months ago
Only for webauth, not SSID that are not configured for webauth.
Overall Rating: 5 (1 ratings)
Stephen Rodriguez Thu, 08/02/2012 - 05:03
  • Purple, 4500 points or more
Yea this is possible. I'd you are just using the WLC you can create the page for each company then load the tar file to the WLC. Under each WLAN you are able to override the default config and choose the page that is appropriate.
If you need a template to follow there is a sample bundle in the same area where you download the WLC code.
Steve
huwyhuwy123 Thu, 08/02/2012 - 05:10
Thanks for replying Stephen.
Are you saying you have to upload the (html) files for the website to the WLC as opposed to redirecting to the actual website?
Alun
Stephen Rodriguez Thu, 08/02/2012 - 09:21
Yes. In the current version you can only redirect to one external URL.
Steve
Scott Fella Thu, 08/02/2012 - 13:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Well you can try to force a redirect from the html code.  Look for this code and make the appropriate changes.
function submitAction(){
      var link = document.location.href;
      var searchString = "redirect=";
      var equalIndex = link.indexOf(searchString);
      var redirectUrl = "";
      var urlStr = "";
      if(equalIndex > 0) {
            equalIndex += searchString.length;
            urlStr = link.substring(equalIndex);
            if(urlStr.length > 0){
        redirectUrl = "http://www.cisco.com";
                                                    if(redirectUrl.length > 255)
        redirectUrl = redirectUrl.substring(0,255);
                                                    document.forms[0].redirect_url.value = redirectUrl;
huwyhuwy123 Thu, 08/02/2012 - 14:42
Thanks for the suggestion Scott - where would I find this code to edit?
Scott Fella Thu, 08/02/2012 - 14:57
  • Hall of Fame,
    2017 Wireless
It's on the custom webauth bundles you can download. So go to the downloads for the 5508 and you will see webauth bundles. That zip file has multiple HTML files for various pages. You can modify those and the code is in there.
You would need to do a custom HTML in order to do this redirect off the HTML page since the wlc limits you to one redirect.
Scott Fella Fri, 08/03/2012 - 11:58
  • Hall of Fame,
    2017 Wireless
huwyhuwy123 Mon, 08/06/2012 - 05:39
Thanks Scott - I really appreciate the help.
Creating a customer webauth page to redirect to different websites sounds really complicated - I'm not sure this is within my range of expertise!
I was thinking of saying we could only redirect to one website.
If I setup the web login page under security - web auth - web login page. Will that apply to all wireless networks? If it does that is a problem!
Cheers again,
Al
Correct Answer
Scott Fella Mon, 08/06/2012 - 05:48
  • Hall of Fame,
    2017 Wireless
huwyhuwy123 Mon, 08/06/2012 - 06:03
Thanks Scott. Last Q - is it difficult to write a custom web auth page?
Scott Fella Mon, 08/06/2012 - 06:05
  • Hall of Fame,
    2017 Wireless
Well the question is if you know (basic) how to edit HTML. If so then it's easy.
Related Content
