AXL: How to find fields needed for AXL command?
Aug 2nd, 2012
Hey guys,
i want to configure my CUCM via AXL and did a tutorial for add Translation Patterns. There are all the fields like blockEnable, networkLocation, routeFilterName, newPattern and so on.
But how can i find ou which field i need for other operations like addRoutePattern or addRoutePartition ?
Best Regards
Daniel
Aaron Harrison Thu, 08/02/2012 - 10:22
  • Community Spotlight Award,
    Member's Choice, May 2015
Hello again Daniel
You need two things:
1) Grab a copy of the AXL schema from your CUCM - go to http://developer.cisco.com/, then select AXL in the drop down on the right hand column. Once there, hit 'documentation'. Grab the AXL schema download, and while you are at it grab the database schema and XML admin guide.
2) If you arent' clear on the fields/values, then instead of trying an 'add' first, create a route pattern normally in the GUI. Then do a 'getRoutePattern', and look at the XMl that is returned to see what fields are and what values can be entered.
Aaron
Related Content
