ipsec site to site vpn help!!
edgsoccer
I im doing a site to site vpn for the first time on a 891 to a rv 120 (gui) but it doesnt connect. I thinking it might be my access list on the 891. the error that i get in the rv120 is
012-08-02 18:15:35: [rv120w][IKE] ERROR:  Phase 1 negotiation failed due to time up for xx.xx.xx.xx[500]. ea65b6c91b9e73de:0000000000000000
2012-08-02 18:16:11: [rv120w][IKE] INFO:  Configuration found for xx.xx.xx.xx.
2012-08-02 18:16:11: [rv120w][IKE] INFO:  Initiating new phase 1 negotiation: xx.xx.xx.xx[500]<=>xx.xx.xx.xx[500]
2012-08-02 18:16:11: [rv120w][IKE] INFO:  Beginning Identity Protection mode.
2012-08-02 18:16:11: [rv120w][IKE] INFO:   [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-08-02 18:16:11: [rv120w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 4
2012-08-02 18:16:11: [rv120w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 8
2012-08-02 18:16:11: [rv120w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 9
2012-08-02 18:16:11: [rv120w][IKE] ERROR:  Ignore information because the message has no hash payload.
2012-08-02 18:16:42: [rv120w][IKE] ERROR:  Invalid SA protocol type: 0
2012-08-02 18:16:42: [rv120w][IKE] ERROR:  Phase 2 negotiation failed due to time up waiting for phase1.
2012-08-02 18:17:00: [rv120w][IKE] INFO:  accept a request to establish IKE-SA: 71.32.110.24
2012-08-02 18:17:00: [rv120w][IKE] WARNING:  schedular is already scheduled for SA creation for remote: "xx.xx.xx.xx"2012-08-02 18:17:00: [rv120w][IKE] ERROR:  Failed to attach schedSaCreate in IKE configuraion
891 config
ip dhcp pool test
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 8.8.8.8 8.8.4.4
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
crypto isakmp policy 1
authentication pre-share
group 2
lifetime 28800
crypto isakmp key Testingkey address xx.xx.xx.xxx
crypto ipsec transform-set test1 ah-md5-hmac esp-3des
crypto map maptest1 2 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set test1
match address 100
interface FastEthernet8
description qwest connection
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
crypto map maptest1
interface Vlan1
description quest
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxx
ppp chap password 0 xxxxxxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 remark maptest1 category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 100 protocol ip permit
Hi Manny,
Thanks for the debug output! I believe we're making some progress and was able to establish IKE phase 1. The problem now is to establish IPsec SA or an IKE phase 2. Could you do the following again one more time and post the results?
int f8
no crypto map maptest1
int d1
crypto map maptest1
clear crypto sa
debug crypto isakmp
debug crypto ipsec
show crypto isakmp sa
show crypto ipsec sa
19 Replies 19
Julio Carvajal
Hello Manny,
Can you change the nat configuration:
ip access-list extended nat
deny ip  10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 10.10.10.0 0.0.0.255 any
no ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list nat interface Dialer1 overload
Also can you do the following on the router after you generate traffic for the VPN
sh crypto isakmp sa
debug crypto isakmp
debug crypto ipsec
And provide us the results.
The configuration on the Remote site related to the VPN stuff will be a plus.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
nat configurations changed.....still not working.. thanks for the help
891 router
crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
xx.xx.xx.24    xx.xx.xx.134   QM_IDLE           2057 ACTIVE
IPv6 Crypto ISAKMP SA
Hi Manny,
Could you re-configure your IKE phase 1 and 2 policies on the 891 as below?
hash md5
no crypto ipsec transform-set test1 ah-md5-hmac esp-3des
crypto ipsec transform-set test1 esp-md5-hmac esp-3des
Changes made but still nothing...
Current running config 891
hash md5
group 2
lifetime 28800
crypto isakmp key Testingkey address xx.xx.xx.134
crypto ipsec transform-set test1 esp-3des esp-md5-hmac
set peer xx.xx.xx.134
match address 100
no ip address
ip nat outside
duplex auto
speed auto
crypto map maptest1
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
RV 120 log
2012-08-03 17:56:23: [rv120w][IKE] WARNING:  schedular is already scheduled for SA creation for remote: "xx.xx.xx.24"2012-08-03 17:56:23: [rv120w][IKE] ERROR:  Failed to attach schedSaCreate in IKE configuraion
2012-08-03 17:56:52: [rv120w][IKE] INFO:  Configuration found for xx.xx.xx.24.
2012-08-03 17:56:52: [rv120w][IKE] INFO:  Initiating new phase 1 negotiation: xx.xx.xx.134[500]<=>xx.xx.xx.24[500]
2012-08-03 17:56:52: [rv120w][IKE] INFO:  Beginning Identity Protection mode.
2012-08-03 17:56:52: [rv120w][IKE] INFO:   [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2012-08-03 17:56:52: [rv120w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 4
2012-08-03 17:56:52: [rv120w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 8
2012-08-03 17:56:52: [rv120w][IKE] INFO:   [ident_i1send:184]: XXX: setting vendorid: 9
2012-08-03 17:56:52: [rv120w][IKE] ERROR:  Ignore information because the message has no hash payload.
2012-08-03 17:57:23: [rv120w][IKE] ERROR:  Invalid SA protocol type: 0
2012-08-03 17:57:23: [rv120w][IKE] ERROR:  Phase 2 negotiation failed due to time up waiting for phase1.
2012-08-03 17:57:37: [rv120w][IKE] INFO:  accept a request to establish IKE-SA: xx.xx.xx.24
ROUTER 891
sh crypto isakmp sa
71.32.110.24    97.77.166.134   MM_NO_STATE          0 ACTIVE (deleted)
debug crypto isakmp
Crypto ISAKMP debugging is on
debug crypto ipsec
Crypto IPSEC debugging is on
But nothing else comes out and dont know how to see the log for 891 to see the errors
Hi Manny,
Could you do:
int f8
int d1
crypto map maptest1
clear crypto isakmp sa
Ping from an internal host/PC behind the 891 and post your results.
changes where made...
891 router
ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
host
PING 192.168.1.1 (192.168.1.1): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
Request timeout for icmp_seq 3
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
^C
--- 192.168.1.1 ping statistics ---
7 packets transmitted, 0 packets received, 100.0% packet loss
thanks you guys i apreciate the help....
sh crypto isakmp sa
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
crypto map maptest1
no ip address
ip nat outside
duplex auto
speed auto
Hi Manny,
Thanks for the update! Could you roll back your config and put back the crypto map under FE8 and post again your complete show run (hide sensitive info)?
aaa new-model
aaa session-id common
memory-size iomem 10
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip dhcp pool test
ip cef
no ipv6 cef
hash md5
group 2
lifetime 28800
match address 100
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
no ip address
ip nat outside
duplex auto
speed auto
crypto map maptest1
interface GigabitEthernet0
description roadrunner connection
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description quest
ip nat inside
interface Vlan2
no ip address
ip nat inside
interface Async1
no ip address
encapsulation slip
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
control-plane
here is my current sh run...thanks john
Hi Manny,
Thanks for the update! I'm suspecting the issue might be on the RV router which hinders IKE phase 1 from establishing.
Could check whether it has PFS (Perfect Forward Secrecy) enabled?
Yes it is enabled
Could you disable/uncheck it on the RV router and try to generate VPN traffic from internal hosts?
John
it didn't work. Do I need to do something additional to the cisco 891 router when i disable psf on the RV router?
hi manny,
could you add this on the 891:
encryption 3des
kindly perform VPN testing this time from behind the RV router by pinging from a host on the 192.168.1.0/24 subnet and post the following results from the 891 router:
cleary crypto isakmp sa
debug crypto isakmp
chages made...
RV router log
2012-08-08 16:12:33: [rv120w][IKE] INFO:  Configuration found for xx.xx.xx.24.
2012-08-08 16:12:33: [rv120w][IKE] INFO:  Initiating new phase 2 negotiation: xx.xx.xx.134[500]<=>xx.xx.xx.24[0]
2012-08-08 16:12:33: [rv120w][IKE] ERROR:  Unknown notify message from xx.xx.xx.24[500].No phase2 handle found.
2012-08-08 16:13:33: [rv120w][IKE] ERROR:  Phase 2 negotiation failed due to time up. 3ac11d27fb281bf1:6b11f2ee9470918b:e4bbd59c
2012-08-08 16:13:33: [rv120w][IKE] INFO:  an undead schedule has been deleted: 'quick_i1prep'.
host 10.10.10.6
PING 192.168.1.100 (192.168.1.100): 56 data bytes
Request timeout for icmp_seq 6
cisco router
xx.xx.xx.24    xx.xx.xx.134   QM_IDLE           2059 ACTIVE
#ping 192.168.1.1
#ping 192.168.1.100
Sending 5, 100-byte ICMP Echos to 192.168.1.100, timeout is 2 seconds:
host 192.168.1.100
Pinging 10.10.10.6 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.10.10.6:
Packets: Sent = 4, Received = 0, Lost = 4 (100% Loss),
but nothing happen even if I ping while ISAKMP debugging is on… any suggestions on how can I see the debugging??
