RV042G V01 NAT/PAT
Aug 2nd, 2012
  • Bronze, 100 points or more
I need to convert an IOS router configuration to a RV042G V01. Is there a way to implement these IOS 12.2 based commands below?
ip nat pool InternetInterface 1.1.1.1 1.1.1.1 netmask 255.255.255.252
ip nat inside source list OutboundInternetTrafficToTranslate interface Ethernet0/1 overload
ip nat inside source route-map nonat pool InternetInterface overload
ip nat inside source static tcp 192.168.1.60 143 interface Ethernet0/1 143
ip nat inside source static tcp 192.168.1.60 8000 interface Ethernet0/1 8000
ip nat inside source static tcp 192.168.1.60 25 interface Ethernet0/1 25
ip nat inside source static tcp 192.168.1.25 5631 208.a.b.c 5631 extendable
ip nat inside source static tcp 192.168.1.25 5632 208.a.b.c 5632 extendable
ip nat inside source static udp 192.168.1.25 5631 208.a.b.c 5631 extendable
ip nat inside source static udp 192.168.1.25 5632 208.a.b.c 5632 extendable
Since I normally configure enterprise products with CLI, I'm ineffective with this GUI and not even sure what this unit can do (PAT?).
Any help is appreciated. Thanks.
Related Content
