Meetingplace 6.1 pptx supported?
Aug 3rd, 2012
Hi Guys,
I would like to ask if pptx file is supported when in meetingplace 6.1 when participants share a documents.
thanks,
Erson
jdedell12 Fri, 08/03/2012 - 08:02
  • Bronze, 100 points or more
Erson,
Almost all documents are supported.  The only thing I have seen issues with is video so you should be all set.
John
teazercool Fri, 08/03/2012 - 09:27
Thanks, though i tried it the pptx seems not able to share. any strategies how to?
jdedell12 Mon, 08/06/2012 - 07:09
When you try to share are you sharing the PowerPoint application or are you uploading the pptx file?  Uploading probaly won't work but sharing the application should.
Amlesh Sengar Tue, 08/07/2012 - 19:10
  • Cisco Employee,
Hi Mark,
  PPTX files are not supported.
You will require .ppt format to upload and share files.
Amlesh
Related Content
