Unity Connection User Import Error
Answered Question
Aug 3rd, 2012
We are using UC version 8.6.2.20000-2.  When I try to import a user, I received following error -
Friday, August 3, 2012 9:45:58 AM EDT ERROR importing user (NAME) with extension = XXXXXX : Department input is invalid
From Tomcat log, I see -
15:36:00.619 |16247,,,Cuca,3,ERROR [pool-7-thread-30] com.cisco.unity.dao.impl.SubscriberDAOImpl  - field validation exception
15:36:00.619 |16247,,,Cuca,2,ERROR [pool-7-thread-30] com.cisco.unity.async.UserImporter  - Exception while importing user: null
15:36:40.411 |16247,,,Cuca,4,ERROR [pool-7-thread-30] com.cisco.unity.datatools.BeanHelper  - invalid field: name=department, value=Executive Administration
, constraint=regex: ^[^\x00-\x1F\x7F]*$
Any help or advice is much appreciated.  Thanks in advance!
Correct Answer by Bradford Magnani about 4 years 8 months ago
Try creating a new test user in the same department in AD and import them to see if they have the same issue.  Trying to narrow down what works and what doesn't will be key.
Hope that helps,
Brad
Overall Rating: 5 (1 ratings)
Bradford Magnani Fri, 08/03/2012 - 07:27
  • Cisco Employee,
Hi Keith,
How are you importing the user?  Directly from LDAP?  BAT with CSV?
Does this happen to all users or only specific ones within that department?
Brad
keithchiang Fri, 08/03/2012 - 07:30
Importing from LDAP.  I can'tconfirm if this is affecting anyone else.
Correct Answer
Bradford Magnani Fri, 08/03/2012 - 09:09
  • Cisco Employee,
Hope that helps,
Brad
keithchiang Fri, 08/03/2012 - 10:55
We created a new AD account with everything the same except using different name and user ID.  I was able to import that user.  We deleted the old AD account and UC account, change the new AD with the original account's user name and ID, resync UC LDAP, import again...success.  Very wierd.  Thank you for your help Bradford.
Related Content
