c 60 coed in 65 dual
Yasir Vistro
we like  to install  C 60 codec in 65 dual  is it work fine  ?
Yasir Vistro
Yasir Vistro
Saurabh Gupta
Level 3
Level 3
Hi Yasir,
Yes, you can install C60 with Dual Screens .
Just Make Sure you have the Dual Display Option key with you so that the second monitor can be activated.
Hope it is informative.
Saurabh
Hi Yasir,
Dual display key is pre loaded in C 60 & C 90 codec . You do not have to install it and also you will not find it in Xstatus .
Kind regards,
Dharmmesh
