Cisco ISE Active Endpoint Usage Reset
CSCO10675262_2
I have a Cisco ISE running version 1.1 and I was wondering if it may be possible to reset the license usage/active endpoint shown on the dashboard? This was noticed after a restore of ISE due to replacement of hardware and I noticed that the license usage count/active endpoints does not seems to go down.
The following methods have been tried however without any success:
1. Reboot ise server/service
2. Disable all network devices making use of ise such that there are no clients/devices accessing it; example switch/wlc/etc...
3. Deleted all endpoints usage in identies/identies group
4. Disable profiling on ise
As the ise has been installed with a base license; not too sure if it may be either a bad restore (all service/application are working though) / bad radius accounting which does not timed out on the ise / etc...
Any help is appreciated on how to reset the active endpoint/license usage.
Thanks.
Tarik Admani
Here is a method for removing the stale records. Please give this a try:
http://www.cisco.com/en/US/docs/security/ise/1.1/api_ref_guide/ise_api_ref_ch2.html#wp1072950
Tarik Admani
*Please rate helpful posts*
5 Replies 5
Tarik Admani
Tarik Admani
Thanks for the information. The active endpoint has been reset successfully.
how did you do that...?
regards,
curl -k -X DELETE https://[user]:[pass]@[primary monitoring node]/ise/mnt/api/Session/Delete/All
Could you send instruction how and where to enter this command? I `ve tried to do that several times...
I know that this command is for linux operating system. But I don`t know how to login into linux shell...
regards,
