cisco 6500 VSS with Sup2T
Answered Question
Aug 5th, 2012
I'm configuring VSS with two Sup2T but the Sup2T of the standby not coming active, any idea?
Correct Answer by Marwan ALshawi about 5 years 1 week ago
i think this need to be port-channel 2 in the secondary VSS
interface port-channel 1 change it 2 and remove the 1 form the standby one
make sure you unplug the VSL links made the changes then connect them again also update the config in the primary VSS switch and save the config before joining them over VSL
hope this help
Correct Answer by Reza Sharifi about 5 years 1 week ago
You have configured the same portchannel number on both sides of the VSL link.  The portchannel numbers need to be different for each side.
switch 1 portchannel 1
switch 2 portchannel 2
Have a look at this link for an example:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSS-dg_appa-configs.pdf
Overall Rating: 5 (2 ratings)
Leo Laohoo Sun, 08/05/2012 - 19:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
More information please?
Post the config, post the "sh log", are both supervisor cards running the same IOS?
abdullahalqarni Sun, 08/05/2012 - 19:41
Thank you for your reply.
yes both Sup running the same IOS
CORE-2#sh module
Mod Ports Card Type                                                      Model
  1   48  CEF720 48 port 10/100/1000mb Ethernet        WS-X6848-GE-TX
  2   24  CEF720 24 port 1000mb SFP                         WS-X6824-SFP
  3    8  DCEF2T 8 port 10GE                                      WS-X6908-10G
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti          VS-SUP2T-10G
Mod MAC addresses                               Hw       Fw                      Sw           Status
  1  a44c.113f.a230 to a44c.113f.a25f       1.0   12.2(18r)S1      15.0(1)SY1           Ok
  2  a44c.110d.3a20 to a44c.110d.3a37    1.0   12.2(18r)S1      15.0(1)SY1           Ok
  3  5057.a81c.8510 to 5057.a81c.8517    1.2   12.2(50r)SYL    15.0(1)SY1           Ok
  5  e05f.b910.b218 to e05f.b910.b21f       1.3   12.2(50r)SYS    15.0(1)SY1           Ok
Mod  Sub-Module                            Model                           Hw     Status
  1  Distributed Forwarding Card       WS-F6K-DFC4-A          1.2        Ok
  2  Distributed Forwarding Card       WS-F6K-DFC4-A          1.2        Ok
  3  Distributed Forwarding Card       WS-F6K-DFC4-E          1.2        Ok
  5  Policy Feature Card 4                VS-F6K-PFC4              1.2        Ok
  5  CPU Daughterboard                   VS-F6K-MSFC5           1.4        Ok
Active Config:
redandancy
mode sso
interface range TenGigabitEthernet5/4 - 5
switchport mode trunk
channel-group 1 mode on
switch virtual domain 10
switch 1
switch 1 priority 110
switch 2 priority 100
switch virtual link 1
switch convert mode virtual
Standby Config:
redandancy
mode sso
interface range  Te2/5/4 - 5
switch 2
switch virtual link 2
Thanks in advance.
Abdullah
Leo Laohoo Sun, 08/05/2012 - 19:52
  • Hall of Fame,
    2017 LAN, Wireless
What error messages do you get when you try to VSS?
Post the "sh logs".
abdullahalqarni Sun, 08/05/2012 - 20:01
i dont have the show log right now.
but after VSS configuration im not able to access the standby chassis via console, because the Sup2T not active, usually you can access it and see it as standby.
Correct Answer
Reza Sharifi Sun, 08/05/2012 - 19:54
    2017 LAN
Correct Answer
Marwan ALshawi Sun, 08/05/2012 - 19:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
hope this help
