VPN Issue - Phase 1 and 2 Complete but limited network access.
Aug 6th, 2012
Hey guys,
I need a little assistance from the experts. I am configuring VPN on an 831 rotuer using a dynamic-map configuration. I can connect to the network and I can see phase 1 and 2 complete from the debugs however from what I can tell I can only ping across the VPN. I can't connect to and web services or RDP to any hosts on the local network. Here is a copy of my config. Any tips would be greatly appreciated.
version 12.4
no service pad
service password-encryption
service sequence-numbers
hostname Babcock_831
boot-start-marker
boot-end-marker
enable secret 5 $1$XbrI$uH9I2gj8/J4SeYrcthWMZ0
aaa new-model
aaa authentication login BABCOCK_AAA local
aaa authorization network BABCOCK_AAA local
aaa session-id common
clock timezone EST -4
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.240 192.168.10.254
ip dhcp excluded-address 192.168.10.193 192.168.10.224
ip dhcp pool BABCOCK
   network 192.168.10.192 255.255.255.192
   default-router 192.168.10.253
   dns-server 8.8.8.8 8.8.4.4
   domain-name babcock.home
   lease 3
ip cef
ip domain name babcock.home
ip name-server 192.168.10.250
ip name-server 8.8.8.8
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto pki trustpoint TP-self-signed-4004683872
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4004683872
revocation-check none
rsakeypair TP-self-signed-4004683872
crypto pki certificate chain TP-self-signed-4004683872
certificate self-signed 01
  30820250 308201B9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303034 36383338 3732301E 170D3132 30333232 31333230
  35375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30303436
  38333837 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100AEF2 01AFC5CA 1B11B96F 3B3E9BD2 5DF2C0BC CF8E2C45 D2DCD973 DA0FF275
  FC33485E 7A2E60BD EBDA37C7 FC2A870F 4E9DC7E1 FB10FDE4 864696B3 74934111
  969AF1C3 B35B59A5 580EFA1C 42F2CB7E CC964797 76167C37 2D6A727C 58D605DB
  C94A3CEC A683C284 56ED0EB4 0C4FBE34 BADE08B9 5ED803AB D4EB383B EB513411
  81F70203 010001A3 78307630 0F060355 1D130101 FF040530 030101FF 30230603
  551D1104 1C301A82 18426162 636F636B 5F383331 2E626162 636F636B 2E686F6D
  65301F06 03551D23 04183016 8014C57E D6AA250A 51248F05 DF37A778 A5286D09
  BBA9301D 0603551D 0E041604 14C57ED6 AA250A51 248F05DF 37A778A5 286D09BB
  A9300D06 092A8648 86F70D01 01040500 03818100 A1DC45C9 76F07483 3289A4DC
  8CD78B29 092AEE13 AEB6B941 F31C3D18 9A52A843 BAC5ABAA A7BB9C7A 95E741DB
  8707C47C 2361A991 873B8B53 1844A525 1E3DDC21 574F31AF 9F89CC56 C1E6ECC0
  B6BE499A A1E074EE CCC96127 E60EA387 CD154FE9 EAE722D1 112032E4 6DFED6BA
  535E3568 58679E3B 6300F953 04F97259 17B098FD
  quit
username elton password 7 072128474B0E160911465F5450
username Babcock_Admin privilege 15 secret 5 $1$..ir$NVB2CmP1lPRVgiAlhHyik1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group VPN_GROUP
key***********
dns 8.8.8.8 8.8.4.4
domain babcock.home
pool VPN_POOL
acl 101
netmask 255.255.255.192
crypto ipsec transform-set VPN_TRANS_SET esp-3des esp-sha-hmac
crypto dynamic-map VPN_DYN_MAP 1
set transform-set VPN_TRANS_SET
reverse-route
crypto map VPN_CMAP client authentication list BABCOCK_AAA
crypto map VPN_CMAP isakmp authorization list BABCOCK_AAA
crypto map VPN_CMAP client configuration address respond
crypto map VPN_CMAP 65535 ipsec-isakmp dynamic VPN_DYN_MAP
interface Ethernet0
description Interface connecting to LAN
ip address 192.168.10.253 255.255.255.192
ip nat inside
ip virtual-reassembly
no cdp enable
interface Ethernet1
description Interface connecting to ISP
ip address dhcp
ip nat outside
duplex auto
no cdp enable
crypto map VPN_CMAP
interface Ethernet2
no ip address
shutdown
no cdp enable
interface FastEthernet1
duplex full
speed 100
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
ip local pool VPN_POOL 192.168.10.193 192.168.10.224
ip forward-protocol nd
ip route 24.176.138.221 255.255.255.255 Ethernet0
no ip http server
ip http secure-server
ip nat inside source list 102 interface Ethernet1 overload
ip nat inside source static tcp 192.168.10.252 8080 interface Ethernet1 8080
ip nat inside source static tcp 192.168.10.250 3389 interface Ethernet1 3389
access-list 1 permit 192.168.10.192 0.0.0.63
access-list 101 permit ip 192.168.10.192 0.0.0.63 any
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.193
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.194
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.195
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.196
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.197
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.198
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.199
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.200
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.201
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.202
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.203
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.204
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.205
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.206
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.207
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.208
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.209
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.210
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.211
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.212
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.213
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.214
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.215
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.216
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.217
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.218
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.219
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.220
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.221
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.222
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.223
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.10.224
access-list 102 permit ip 192.168.10.192 0.0.0.63 any
no cdp run
control-plane
line con 0
password 7 082F45450C1E0A1B145F585C7E
logging synchronous
no modem enable
line aux 0
line vty 0 4
password 7 011D0F0F5E0C090327181A514D
logging synchronous
transport input ssh
scheduler max-task-time 5000
ntp clock-period 17179663
ntp server 64.90.182.55
end
Overall Rating: 5 (1 ratings)
Jennifer Halim Mon, 08/06/2012 - 22:37
  • Cisco Employee,
The VPN Client pool can't be in the same subnet as your internal LAN subnet. It should be unique subnet.
Further  to that, since you are configuring static PAT, you won't be able to  access the following 2 ip addresses using its real IP when connected to  the VPN:
192.168.10.252
192.168.10.250
Using the public IP should work however because static PAT can't be NAT exempted.
BigDawgFelton Tue, 08/07/2012 - 17:23
Hello Jennifer,
Thanks for you help earlier. I have re-done my configuration which included removing the static NAT entries along with changing the subnet that the VPN users land in once they connect.
Speeds seem much slower than when I had the VPN users drop into the same subnet as the rest of the network. However it is working. I can only begin to ping the VPN user once they initiate traffic, but I assume this is normal.
One issue that I am seeing is a log on the router when the VPN user initiates traffic such as web services or RDP. The connection works but is very slow. this connection has about a 5Meg upload speed. Here is the log that I am seeing along with my updated configuration. I assume it has to do with the virtual-reassembly and I know I can increase the value but I want to know if this is the actual fix or just a coverup of the actual problem.
003196: Aug  8 00:21:27.825: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Ethernet1: the fragment table has reached its maximum threshold 16
version 12.4
no service pad
boot-start-marker
boot-end-marker
aaa new-model
   lease 3
ip cef
  quit
encr 3des
group 2
key **********
dns 8.8.8.8 8.8.4.4
domain babcock.home
pool VPN_POOL
acl 103
netmask 255.255.255.240
reverse-route
interface Ethernet0
ip nat inside
no cdp enable
interface Ethernet1
ip address dhcp
ip nat outside
duplex auto
no cdp enable
crypto map VPN_CMAP
interface Ethernet2
no ip address
shutdown
no cdp enable
duplex full
speed 100
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
ip local pool VPN_POOL 192.168.255.241 192.168.255.254
no ip http server
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.241
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.242
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.243
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.244
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.245
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.246
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.247
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.248
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.249
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.250
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.251
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.252
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.253
access-list 102 deny   ip 192.168.10.192 0.0.0.63 host 192.168.255.254
access-list 103 permit ip 192.168.255.240 0.0.0.15 any
access-list 103 permit ip 192.168.10.192 0.0.0.63 any
no cdp run
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
logging synchronous
transport input ssh
ntp clock-period 17179656
end
Jennifer Halim Wed, 08/08/2012 - 00:52
  • Cisco Employee,
Try to configure a lower MSS value on your LAN interface so a smaller packet is negotiated for TCP traffic:
interface ethernet0
  ip tcp adjust-mss 1300
BigDawgFelton Tue, 08/07/2012 - 06:01
Thanks I'll try this later on today and confirm that it works. I had a feeling that it had something to do with my static NAT entries.
BigDawgFelton Wed, 08/08/2012 - 18:22
I don't have this exact command in my router. I had "ip tcp mss 1300"
This however didnt fix the issue. When I initiate large amounts of traffic over the tunnel I still receive the log message on the router. The connection is very slow. Any other ideas you might have?
johnlloyd_13 Wed, 08/08/2012 - 19:00
  • Blue, 1500 points or more
Hi Elton,
Could you negate the said line and see if the log still shows up?
int e1
no ip virtual-reassembly
