Too much noise while calling
Aug 6th, 2012
I have MGCP gateway, when i make external call using MGCP gateway. I heared lots of noise.....
Its b/c of Physical layer or service provider issue or E1 card issue.
Thank You
ronpatel Mon, 08/06/2012 - 22:50
  • Blue, 1500 points or more
Do clear counters for the Controller and see if you have error increasing. If yes may be you have problem with the line.
Ronak patel
Rate helpful posts.
