Warning message
1042n AP can't get DHCP for guest network
Answered Question
Aug 3rd, 2012
This is rattling my brain. I have configured 2 SSIDs, one for internal, one for guests. They are on seperate VLANs (50 and 51) and bridge groups (1 and 2). I can get IPs via DHCP for the internal network, but not for the guest. I can't get DHCP for any VLAN 51 sub-interface, nor clients that connect to it. The overall goal is to keep all traffic on the guest network seperate from the internal traffic, however, DHCP requests will be from an internal server. I have removed all the access-lists for troubleshooting purposes. AP and Switchport configs are below! Please help!
AP Config
Current configuration : 4011 bytes
version 12.4
no service pad
service password-encryption
hostname Test
logging rate-limit console 9
enable secret 5
aaa new-model
aaa group server radius rad_eap
server 192.168.75.49 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip dhcp-server 192.168.75.49
dot11 mbssid
dot11 syslog
dot11 ssid Guest
   vlan 51
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7
dot11 ssid Internal
   vlan 50
   authentication open eap eap_methods
   mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
ip helper-address 192.168.75.49
no ip route-cache
encryption vlan 50 mode ciphers aes-ccm
encryption vlan 51 mode ciphers aes-ccm
ssid Guest
ssid Internal
antenna gain 0
station-role root
interface Dot11Radio0.50
encapsulation dot1Q 50 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.51
encapsulation dot1Q 51
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Guest
ssid Internal
antenna gain 0
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.50
no ip route-cache
bridge-group 1
interface Dot11Radio1.51
no ip route-cache
bridge-group 2
interface GigabitEthernet0
ip address dhcp
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.50
ip address dhcp
no ip route-cache
bridge-group 1
interface GigabitEthernet0.51
ip address 192.168.51.100 255.255.255.0
no ip route-cache
interface BVI1
ip address dhcp
no ip route-cache
interface BVI2
ip address dhcp
no ip route-cache
ip default-gateway 192.168.50.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.75.49 auth-port 1645 acct-port 1646 key 7
radius-server vsa send accounting
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
transport input all
end
Switchport Config
interface GigabitEthernet0/11
switchport trunk native vlan 50
switchport trunk allowed vlan 50,51
switchport mode trunk
end
Correct Answer by Scott Fella about 5 years 1 week ago
Okay... the BVI interface on your AP is your management address for the AP, so this need to be native vlan on the trunk.  You do not need BVI2 not do you need to have an ip address for the gigabit0 interface.
Overall Rating: 5 (1 ratings)
Scott Fella Fri, 08/03/2012 - 13:17
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Do you have the ip helper defined on your Layer 3 interface for vlan 51?
Amjad Abdullah Sun, 08/05/2012 - 23:49
  • Red, 2250 points or more
Do you have interface VLAN50/ VLAN51 configured on the neighbor swtich? if yes please provide the config.
Why are you using DHCP to provide ip addresses to the BVI interfaces?
Do both your BVI interfaces get an IP address correctly from your DHCP server?
Confirm please that your DHCP server is 192.168.75.49 for both VLANs.
Where is the DHCP server configured? on a switch or third-party server?
KevlarDud Mon, 08/06/2012 - 08:47
Scott: Do you have the ip helper defined on your Layer 3 interface for vlan 51?
Yep, we have the IP helper on the switch for both VLANs.
Amjad: Do you have interface VLAN50/ VLAN51 configured on the neighbor swtich? if yes please provide the config.
I do, here is the config:
interface Vlan50
ip address 192.168.50.1 255.255.255.0
ip route-cache policy
interface Vlan51
ip address 192.168.51.1 255.255.255.0
The interfaces are set to DHCP for testing. My production APs have statics. I figured it's easier to t-shoot the DHCP issue with the BVI interface rather than assigning a static and then t-shooting from a client laptop.
Only BVI1 gets the DHCP address correctly.
Confirmed. 75.49 is the DHCP server for both VLANs.
The DHCP server is a Windows 2008 R2 server. I have tested putting DHCP on the switch, this works, but I'd rather manage it from the Windows server.
Correct Answer
Scott Fella Mon, 08/06/2012 - 18:08
  • Hall of Fame,
    2017 Wireless
KevlarDud Tue, 08/07/2012 - 07:37
That was it, thank you. I guess if you have a 2nd BVI, bridge-group 2 will route through that rather than through BVI1. I also didn't realize that you only need an IP on the native VLAN rather than on both VLANs.
Here's my configs in case others are confused:
AP Config:
Test#show ip int br
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.50.127  YES DHCP   up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.50             unassigned      YES unset  up                    up
Dot11Radio0.51             unassigned      YES unset  up                    up
Dot11Radio1                unassigned      YES NVRAM  up                    up
Dot11Radio1.50             unassigned      YES unset  up                    up
Dot11Radio1.51             unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.50        192.168.50.126  YES DHCP   up                    up
GigabitEthernet0.51        unassigned      YES DHCP   up                    up
Test#show run
Building configuration...
Current configuration : 3935 bytes
version 12.4
no service pad
hostname Test
aaa new-model
dot11 mbssid
dot11 syslog
dot11 ssid Guest
   vlan 51
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7
dot11 ssid Internal
   vlan 50
   mbssid guest-mode
bridge irb
no ip address
no ip route-cache
ssid Guest
ssid Internal
antenna gain 0
station-role root
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
no ip address
no ip route-cache
ssid Guest
ssid Internal
antenna gain 0
dfs band 3 block
channel dfs
station-role root
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
ip address dhcp
no ip route-cache
bridge-group 1
ip address dhcp
no ip route-cache
bridge-group 2
interface BVI1
ip address dhcp
no ip route-cache
ip http server
snmp-server community cisco RO
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
logging synchronous
transport input all
end
Switchport Config
end
Scott Fella Tue, 08/07/2012 - 07:45
  • Hall of Fame,
    2017 Wireless
Glad you got it working. Thanks for using the rating system!
Related Content
