Showing results forĀ
Search instead forĀ
Did you mean:Ā
ASA send syslog messages for configuration changes
Timothy Chan
On a router you can send configuration changes to the syslog server by doing,
conf t
archive
log config
logging enable
notify syslog
Then the router will send something like,
.Aug  3 13:12:00.776 PACIFIC: %PARSER-5-CFGLOG_LOGGEDCMD: User:admin  logged command:no interface Loopback76
if I had typed at the command line, "no int lo76"
How do you do this on the ASA?
Goal:  I want to know when anybody does any kind of config on my ASA.
Jennifer Halim
The syslog number 111008 and 111010 will log the command that is entered by user.
111010 is for configuration changes.
Here is the syslog for your information:
111008:
http://www.cisco.com/en/US/docs/security/asa/asa84/system/message/logmsgs.html#wp4769400
111010:
http://www.cisco.com/en/US/docs/security/asa/asa84/system/message/logmsgs.html#wp4769410
You need to enable syslog, and severity level 5, and if you don't want to see any other logging, you can only log the above 2 syslog numbers.
Jennifer Halim
111008:
111010:
Thanks, here's what I did,
logging list notif-cfg-changes message 111008-111010
logging list notif-cfg-changes level errors
logging trap notif-cfg-changes
I think this means send those specific messages even though they are a higher numbered level (5) than the 'error' level 3.  Then send level 3 messages.
My syslog server gets the 111008 messages.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/monitor_syslog.html#wp1064820
