Warning message
Map 300 different VLANs to a SSID?
Aug 7th, 2012
Hi Everyone,
I've just come across a situation where the customer requires to have their 300 different VLANs (they got 300 stores across AU) to be mapped to the same SSID. I know this is doable by creating an interface group on the WLC that contains all 300 VLAN interfaces, then map the interface group to the SSID. However, is there a better way to do it? I meant I don't think creating 300 interfaces on the WLC is a good idea from a managment point of view.
Thanks you in advanced for your time and for sharing your wisdom.
Nhan.
Nhan Ho Wed, 08/15/2012 - 00:03
Could someone please give me some idea about this problem?
Thanks and regards,
Nhan.
alepatte Fri, 08/17/2012 - 10:03
Hi Nhan,
This post in Small Business Forum and you need to address this in Enterprise Level Forum.
Thank you.
