Warning message
MCS Servers CAN BootUp Automatic ?
Aug 7th, 2012
  • Silver, 250 points or more
We are wondering if exist a workaround for BootUP Automatic MCS servers when we have a power failure
Is possible to boot auto these servers?
cc
ronpatel Tue, 08/07/2012 - 23:11
  • Blue, 1500 points or more
For MCS , I dont think we have any option to make it auto boot after power failure. You have to manaully start it.
Ronak patel
Rate helpful posts.
Aman Soi Wed, 08/08/2012 - 02:09
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 IP Telephony
Hi CC,
We have Automatic Server restart feature [ASR] available on MCS IBM servers.This option appears in BIOS setup [u need to enter into it and enable this option].I have checked on MCS IBM servers and it works.
Please check out and let me know.
regds,
aman
Joseph Martini Wed, 08/08/2012 - 02:54
  • Cisco Employee,
My understanding of ASR is not that it will boot up a server that has lost power but rather, "The Automatic Server Restart event occurs when the operating system locks up and no longer responds. Subsequently, a system restart (reboot) begins."
http://publib.boulder.ibm.com/infocenter/eserver/v1r2/index.jsp?topic=%2Fdiricinfo%2Ffqm0_r_events_cim_system_automatic_server_restart.html
If you've tested this though by pulling the power from a server and it did boot up again only with that setting enabled that's good to know.
chrysostomos1980 Wed, 08/08/2012 - 03:00
Thnak you AMAN nad JOE for your Replies
I will check it and i will return back with a feedback
I will rate your posts if its worked
Aman Soi Tue, 05/12/2015 - 05:59
    2017 IP Telephony
yes it works.
after the power fails and power supply is connected with ASR set and power comes , the server boots UP
regds,
aman
