mls qos on 3560 switch
Answered Question
Aug 8th, 2012
Hi All,
We have just enabled "mls qos" and executed default mls qos values.
Can you please explain me in simple words ,what it does ?
Sri
Correct Answer by John Blakley about 5 years 1 week ago
COS stands for "class of service" and is l2 only. COS values are from 0 - 7 with 0 being low priority and 7 being high priority. Generally, phones will mark with cos 5 or a dscp value of 46 (EF). There is a cos-dscp mapping that happens outbound on the switch when it sends to the router for the router to see the dscp value that was converted from the internal map on the switch. Once your traffic is tagged at ingress (on switchport), the tag is carried to the output queue on the switch which leads to the router.
Here's something to read:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_55_se/configuration/guide/swqos.html
QoS is a very big topic...
Overall Rating: 5 (1 ratings)
John Blakley Wed, 08/08/2012 - 04:14
  • Purple, 4500 points or more
It enables qos globally on the switch across all ports. By default, the switch will mark everything with cos 0.
HTH,
John
s.kanth Wed, 08/08/2012 - 04:17
Thanks john for your quicky reply..
COS is L2 QOS, what is L2 QOS.. please explain me in a short ?
Sri
Correct Answer
John Blakley Wed, 08/08/2012 - 04:23
s.kanth Wed, 08/08/2012 - 04:32
Hi John,
Thanks for your info.. Got it what i am looking for :-)
Joseph W. Doherty Wed, 08/08/2012 - 05:29
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just want to mention . . .
L2 CoS requires VLAN tags to provide the CoS field between devices.
L3 ToS is part of every IP packet header.  DSCP is the current recommendation for using the first 6 bits of the ToS byte.
Some "modern" L2 intelligent/smart switches support examination of L3 ToS.
The term CoS might also be use generically or for internal switch QoS treatment (on some Cisco switches).
Related Content
