Black Screen when playing a multicast stream
Aug 8th, 2012
I am running DMS 5.2.2. I have a scientific Atlanta encoder which i use for enterprise tv. I have created a media asset that carries the multicast stream and then put it on a presentation. When i push the presentaion to the dmp, i am able to see the stream but the screen goes black periodically for about 2 to 3 seconds and then resumes. Any ideas.
Gathara
panayiotiscy Wed, 08/08/2012 - 04:30
Hello Martin,
I remember experiencing this in the past.
You should play a bit with the jitter settings under the multicast setting of the dmpd.
Increase the ms setting and this should do your job.
sdhanral Wed, 08/08/2012 - 05:48
  • Bronze, 100 points or more
Please confirm the exact multicast URL that you have in the asset.
Is it UDP://: or udp://:
Note the case difference in the URL.
Sagar Dhanrale
