Warning message
Limit speed on port or VLAN? - ASA 5505
Aug 8th, 2012
We need to have one connection with less internet bandwidth assigned to it than all other other connections. Basically it is a separate conection from all others, incomming just from one switch port and separate VLAN
I know this can be done on the switch by limiting the bandwidth allocated to a port,
Switch(config)# interface gigabitethernet2/0/1
Switch(config-if)# srr-queue bandwidth limit 80
however, is it possible to have the speed limited down, just before it goes to the internet, ie, on the ASA, rather than doing it on the switch?
The firewall is an ASA 5505
Thank you in advance
Overall Rating: 5 (1 ratings)
Related Content
