(p3sm –-show) on supsciper manager (SCE)
Aug 8th, 2012
Hi All,
When I issue the command (> p3sm –-show) on the supsciper manager machine I can notice the following line.
Do anybody know what is the meaning of it.
LEG block mode is on:              false.
And how to enable (Auto-resync at SCE reconnect)
Sample output:
> p3sm –-show
Subscriber Management Module Information:
Persistency in SCE (static):       false
Auto-resync at SCE reconnect:      false
Save subscriber state on logout:   false
Pull mode is on:                   false
Logon logging is on:               false
Statistics:
Number of logins:                  1872423
Number of logouts:                 1824239
Number of auto-logouts:            0
Number of pull requests:           0
LEG-SM link failure:
Clear all subscribers mappings:    false
Timeout:                           60
Up time:                           4 hours 16 minutes 44 seconds
Inactive Subscribers Removal:
Is Enabled:          false
Inactivity timeout:  1 hours
Max removal rate:    10 subscribers per second
Task interval:       10 minutes
Last run time:       Was never run
Automatic Logout (lease-time support):
Is Enabled:          false
Max logout rate:     50 IP addresses per second
Task interval:       disabled
Grace period:        10 seconds
Command terminated successfully
Mohamed
Related Content
