Onplus on android tablet
Aug 8th, 2012
Hi guys,
I am trying to use the android app for onplus, but the inventory screen hangs on the inventory screen and crashes the app. It happens on multiple sites.
I am using ics on my tablet, and I have downloaded the current version from the store.
What other info would you like?
Thanks!
Sent from Cisco Technical Support Android App
aqkazi Thu, 08/09/2012 - 07:50
  • Bronze, 100 points or more
Hi Chris,
I have the app running well on Android with ICS. When you rotate the device horizontally, does it display the topology? It may take some time to load but it should display. Then once you rotate it back it should display the inventory.
The OnPlus Team
