3945 Ethernet Switch Module
Aug 9th, 2012
I have a Ethernet module (SM-ES3G-16-P) installed in a 3945 router and noticed during first boot no licenses are active at all. I would assume at a mimimum ipbase would be active.
With this module, does static routing work with just ipbase?
Example:
interface g0/1
no switchport
ip addr 192.168.254.2 255.255.255.0
int vlan 1
ip addr 172.16.1.2 255.255.255.252
ip route 0.0.0.0.0 0.0.0.0 172.16.1.1
switch#show license
Index 1 Feature: advipservices
        Period left: 0  minute  0  second
Index 2 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 3 Feature: ipbase
Thanks!
Alessio Andreoli Thu, 08/09/2012 - 09:26
  • Silver, 250 points or more
Yes it does. Static routing will work with ipbase.
Alessio
Spagsterj Thu, 08/09/2012 - 16:50
Is there a maximum of static routes?
Peter Paluch Sun, 08/12/2012 - 07:09
  • Cisco Employee,
I do not recall seeing any artificial limit on the count of static routes with IP Base on 3945 routers. I believe there is no practical limit.
Best regards,
Peter
Wilson Gabriel ... Thu, 12/05/2013 - 12:10
Hello  Spagster
The configuration taht you post is all from de SM. also can you help me with the steps to do the initial configuration f the SM
