Warning message
interpret failover command on my asa
Answered Question
Aug 9th, 2012
Hi Everyone, thank you very much for your help in advance...
I would like to ask if you can help if you can interpret each line of the following commands means, and how the failover works (with the settings below)?
failover
failover lan unit primary
failover lan interface failover Management0/0
failover polltime unit 3 holdtime 9
failover replication http
failover link failover Management0/0
failover interface ip failover 192.168.0.1 255.255.255.240 standby 192.168.0.2
icmp unreachable rate-limit 1 burst-size 1
failover
THank you very much for your help
Takami chiro
Correct Answer by zujalal about 5 years 1 week ago
failover : Enables Failover.
failover lan unit primary : Makes the unit that this command is entered as the primary FW
failover lan interface failover Management0/0: Specify which interface will be used for exchanging FW Hellos and other messges.
failover polltime unit 3 holdtime 9 : This command changes  the frequency at which Failover hellos are sent to the other FW
failover replication http : Enter this if you want http sessions to be replicated to the standby FW. if this is entered, user will not have to refresh his browser.
failover link failover Management0/0 : Specify the interface for exchanging state information.
failover interface ip failover 192.168.0.1 255.255.255.240 standby 192.168.0.2 : Specify the Failover IP addresses.
Zubair
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Thu, 08/09/2012 - 11:37
  • Green, 3000 points or more
Get  used to referencing these links bellow ,  look at command line syntax for each command .   Read the " Usage Guidelines "  that explains each command usage.
Command reference failover
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/ef.html
This is how failover works,  read this link  - Active/Standby   failover  overview
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
Correct Answer
zujalal Thu, 08/09/2012 - 21:00
  • Cisco Employee,
Zubair
riderfaiz Mon, 08/13/2012 - 10:03
Thank you very much for everyone of the helps here! Cheers~~
