Activating the Fabric Interconnect Firmware for a Cluster Configuration
ADAman
I have been following the upgrade Guide within 2.0. everything went smooth until I started on the FIs. I activated the FI-B first, then I set FI-B as the lead. Since then I have not been able to log into UCSM GUI. The virtual IP is not responding. FI-B is not responding on ping also.
The problem started at the end of page 40 in the "Upgrade UCS from 2.0 to 2.x" guide.
Is there a way to restart the web-server, perhaps? Bear in mind I am in the middle of a upgrade scenario. I have different firmware on the two FIs, because the FI-B has already been upgraded according to the instructions in the Upgrade Guide.
When I log into he two FIs, everything seems to be normal. I think the problem could have arosen, because of the strange 10 minute time difference I have reported earlier today.
See output from events here.
FI6120XP-A# scope fabric-interconnect a
FI6120XP-A /fabric-interconnect # show fault
Severity  Code     Last Transition Time     ID       Description
Cleared   F16550   2012-08-09T20:55:29.330    167299 [FSM:STAGE:RETRY:]: Uplink
eth port configuration on A(FSM-STAGE:sam:dme:SwEthLanBorderDeploy:UpdateConnect
ivity)
Cleared   F16550   2012-08-09T20:55:29.330    167303 [FSM:STAGE:RETRY:]: Uplink
fc port configuration on A(FSM-STAGE:sam:dme:SwFcSanBorderDeploy:UpdateConnectiv
ity)
Info      F0279    2012-08-09T12:39:44.804     44806 fc port 6 on fabric interco
nnect A oper state: sfp-not-present
Info      F0279    2012-08-09T12:39:44.803     44801 fc port 1 on fabric interco
Info      F0279    2012-08-09T12:39:44.803     44802 fc port 2 on fabric interco
Info      F0279    2012-08-09T12:39:44.803     44803 fc port 3 on fabric interco
Info      F0279    2012-08-09T12:39:44.803     44804 fc port 4 on fabric interco
Info      F0279    2012-08-09T12:39:44.803     44805 fc port 5 on fabric interco
Major     F0374    2012-08-07T14:44:23.960    115262 Power supply 1 in fabric in
terconnect A operability: inoperable
Major     F0369    2012-08-07T14:44:23.959    115261 Power supply 1 in fabric in
terconnect A power: error
FI6120XP-A /fabric-interconnect #  exit
FI6120XP-A# scope fabric-interconnect b
Cleared   F16550   2012-08-09T20:55:29.330    167301 [FSM:STAGE:RETRY:]: Uplink
eth port configuration on B(FSM-STAGE:sam:dme:SwEthLanBorderDeploy:UpdateConnect
ivity)
Cleared   F16550   2012-08-09T20:55:29.330    167305 [FSM:STAGE:RETRY:]: Uplink
fc port configuration on B(FSM-STAGE:sam:dme:SwFcSanBorderDeploy:UpdateConnectiv
ity)
Major     F0276    2012-08-09T20:40:14.059    103277 ether port 5 on fabric inte
rconnect B oper state: link-down, reason: Link failure or not-connected
Major     F0276    2012-08-09T20:40:14.059    103279 ether port 7 on fabric inte
Cleared   F16550   2012-08-09T20:39:29.666    168434 [FSM:STAGE:RETRY:]: interna
l network configuration on B(FSM-STAGE:sam:dme:SwAccessDomainDeploy:UpdateConnec
tivity)
Cleared   F0278    2012-08-09T20:38:37.860    168199 ether port 20 on fabric int
erconnect B oper state: hardware-failure, reason: hardware-failure
Cleared   F0278    2012-08-09T20:38:37.566    168200 ether port 19 on fabric int
Cleared   F16653   2012-08-09T20:38:33.969    168210 [FSM:STAGE:RETRY:]: rebooti
ng remote fabric interconnect(FSM-STAGE:sam:dme:MgmtControllerUpdateSwitch:reset
Remote)
Cleared   F0291    2012-08-09T20:37:19.381    168209 Fabric Interconnect B opera
bility: inoperable
Major     F0369    2012-08-07T14:44:52.779    115581 Power supply 1 in fabric in
terconnect B power: error
Major     F0374    2012-08-07T14:44:52.779    115582 Power supply 1 in fabric in
terconnect B operability: inoperable
Info      F0279    2012-07-06T10:43:49.427     50643 fc port 5 on fabric interco
nnect B oper state: sfp-not-present
Info      F0279    2012-07-06T10:43:49.427     50644 fc port 6 on fabric interco
Info      F0279    2012-07-06T10:43:49.426     50640 fc port 2 on fabric interco
Info      F0279    2012-07-06T10:43:49.426     50641 fc port 3 on fabric interco
Info      F0279    2012-07-06T10:43:49.426     50642 fc port 4 on fabric interco
Info      F0279    2012-07-06T10:43:49.425     50639 fc port 1 on fabric interco
12 Replies 12
ADAman
This is in main event-log:
FI6120XP-A# show event
Creation Time            ID       Code     Description
2012-08-09T21:40:59.700    183964 E4195227 [FSM:STAGE:REMOTE-ERROR]: Result: end
-point-unavailable Code: ERR-NTP-set-error Message: Device Name:[0x3FF] Instance
:[63] Error Type:[(null)] code:[255](sam:dme:CommSvcEpUpdateSvcEp:SetEpLocal)
2012-08-09T21:40:59.699    183963 E4195227 [FSM:STAGE:STALE-FAIL]: communication
service  configuration to primary(FSM-STAGE:sam:dme:CommSvcEpUpdateSvcEp:SetEpL
ocal)
2012-08-09T21:40:00.555    183961 E4195227 [FSM:STAGE:STALE-FAIL]: communication
ocal)
2012-08-09T21:40:00.555    183962 E4195227 [FSM:STAGE:REMOTE-ERROR]: Result: end
2012-08-09T21:38:49.703    183959 E4195227 [FSM:STAGE:STALE-FAIL]: communication
ocal)
2012-08-09T21:38:49.703    183960 E4195227 [FSM:STAGE:REMOTE-ERROR]: Result: end
2012-08-09T21:37:40.335    183929 E4195227 [FSM:STAGE:STALE-FAIL]: communication
I cannot log in with SSH to FI-B also. Remember, I reported a problem setting the clock on FI-B? It was always 10 minutes faster. The error above is on FI-A, but I think it is on FI-B also. I wil now try to set the clocks again on both FIs.
ADAman
I took a backup of the full config. Will a restore set it back to where I started? (But still a problem with time differences)
ADAman
FI6120XP-B# show cluster extended-state
Cluster Id: 0xd03a569cc74311e1-0x9ad4000decfbaec4
Start time: Thu Aug  9 20:46:42 2012
Last election time: Thu Aug  9 20:52:26 2012
B: UP, PRIMARY
A: UP, SUBORDINATE
B: memb state UP, lead state PRIMARY, mgmt services state: UP
A: memb state UP, lead state SUBORDINATE, mgmt services state: UP
   heartbeat state PRIMARY_OK
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, UP
HA READY
Detailed state of the device selected for HA storage:
Chassis 1, serial: FOX1338GY8D, state: active
FI6120XP-B#
IOM 1 (Fabric A):
        Running-Vers: 2.0(1t)
        Package Vers: 2.0(1t)A
        Update-Status: Ready
        Activate-Status: Pending Next Boot
    IOM 2 (Fabric B):
        Running-Vers: 2.0(3b)
        Package Vers: 2.0(3b)A
        Activate-Status: Ready
I will reboot FI-A (it did not say this).
That did not help. Same situation. Cluster is reporting it is ok, but I cannot log into both virtual and FI-B.
ADAman
I think somehow this step went wrong:
Step 2 To activate the IOM firmware, do the following in the Activate Firmware dialog box:
a) From the Filter drop-down list, choose IO Modules.
b) From the Set Version drop-down list, choose the version for the current 2.0 release.
c) Check the Ignore Compatibility Check check box.
d) Check the Set Startup Version Only check box.
When you configure Set Startup Version Only for an I/O module, the I/O module is rebooted
when the fabric interconnect in its data path is rebooted. If you do not configure Set Startup
Version Only for an I/O module, the I/O module reboots and disrupts traffic. In addition, if
Cisco UCS Manager detects a protocol and firmware version mismatch between the fabric
interconnect and the I/O module, Cisco UCS Manager automatically updates the I/O module
with the firmware version that matches the firmware in the fabric interconnect and then
activates the firmware and reboots the I/O module again.
Important
e) Click Apply.
When the Activate Status column for all IOMs displays pending-next-boot, continue with Step 3.
Step 3 Click OK.
Because:
IOM-A seems never to be activated, because the package-version is 2.0(1t)
FI6120XP-A# show iom version
Chassis 1:
    IOM      Fabric ID Running-Vers    Package Vers   Update-Status   Activate-Status
           1 A         2.0(1t)         2.0(1t)A       Ready           Pending Next Boot
           2 B         2.0(3b)         2.0(3b)A       Ready           Ready
ADAman
Severity: Major
Code: F0910
Last Transition Time: 2012-08-09T20:22:39.621
Status: None
Description: default Keyring's certificate is invalid, reason: expired.
Affected Object: sys/pki-ext/keyring-default
Name: Pki Key Ring Status
Cause: Invalid Keyring Certificate
Type: Security
ADAman
Since the IOM firware is different on IOM-A, I think maybe start there?
Is this how I do it (Cannot do this in scope firmware)
FI6120XP-A /system # activate firmware  ucs-2100.2.0.3b.bin (I have a 2104XP)
ADAman
I now understand more. The reason FI-A and IOM-A are showing old packages is that IOM-A will only upgrade to the newest version when we activate the new fw for FI-A. So the solution may be to go ahead and do this on CLI. Then they both will be updated.
But my gui problem may still be there. This may be 2 different problems. I just thought the GUI problem was related to this.
ADAman
I am thinking to activate these two:
Kernel: ucs-6100-k9-kickstart.5.0.3.N2.2.03b.bin
System: ucs-6100-k9-system.5.0.3.N2.2.03b.bin
In Gui these are done at the same time. Here they will have to be executed on at a time.
ADAman
This can be closed. We found the mistake: The FI-B was connected with mgmt1 interface. Therefore when we switched management over to FI-B we could no longer access the GUI...The same error caused my time sync issues.. Tis can be closed.
thanks for the post really helped us
