Inter-cluster trunk(Non gatekeeper controlled) between 7.1.5 to 4.1.2
Aug 10th, 2012
Hi all,
I have configured  ICT(Non gatekeeper controlled) between call manager cluster  7.1.5 <--> 4.1.2. But could not able to establish calls between these cluster .After reviewing the logs looks like ICT not yet established.
Can someone guide me on compatibility for ICT(Non gatekeeper controlled) between call manager cluster  7.1.5 <--> 4.1.2 ?
06/27/2012 15:43:43.177 CCM|H225Cdpc(0004401)::requestConnect_H225TcpTimer: H225 Call is aborted as no response received for H225 Tcp Start Session Request within configured H225TcpTimer value|<CLID::StandAloneCluster><NID::10.22.160.168><CT::2,100,154,4401.1><IP::><DEV::><LVL::Error><MASK::0100>
06/27/2012 15:43:43.177 CCM|RouteListCdrc::checkQ931CauseCode - configuration is empty|<CLID::StandAloneCluster><NID::10.22.160.168><CT::2,100,154,4401.1><IP::><DEV::><LVL::Detailed><MASK::0800>
06/27/2012 15:43:43.177 CCM|RouteListCdrc::terminateCall - No more Routes in RouteListName = SIEMENS-RL.  Rejecting the call|<CLID::StandAloneCluster><NID::10.22.160.168><CT::2,100,154,4401.1><IP::><DEV::><LVL::Detailed><MASK::0800>
Chris Deren Fri, 08/10/2012 - 06:47
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
They are definitely compatible.  How many servers do you have on each side? Are all servers referenced in the trunks?
Is there a firewall between the clusters?
Chris
Nagabhushana .g Fri, 08/10/2012 - 07:57
Chris,
In each cluster we have 5 servers include PUB, This ICT is pointed to two subscribers. I'm not sure about firewall if so.. could you please share the ports used for ICT ?,so I can check the network connectivity between these cluster.(ping and tracert works fine).
Chris Deren Fri, 08/10/2012 - 08:01
  • Hall of Fame,
You need to ensure that the servers you are pointing to match the servers assigned to the CM Group that is referenced by the device pool assigned to the ICT on the other side.
So, cluster A has server 1,2,3,4,5
cluster B has servers 6,7,8,9,10
ICT on cluster A can only point to 3 servers, i.e. 6,7,8
ICT on cluster B has DP--> CM group with servers 6,7,8 listed and it points to servers 1,2,3 which are similarly assigned on the other side.
I belive this is nicely described in SRND doc.
HTH,
Chris
Related Content
