LISP runs great in GNS3/dynamips
Aug 10th, 2012
So if you're interested in testing LISP, download the latest engineering release from lisp.cisco.com for the 7200 (contract required, of course) and give it a try.  I've been very happy with LISP and after extensive testing in GNS3 have been running LISP VPN in production now for months as an alternative to DMVPN.  I can post some configs if anyone is interested, although it is very easy to configure.
HTH,
Matt
Overall Rating: 5 (3 ratings)
danielkuhl Mon, 09/24/2012 - 01:26
Hi Matt,
which IOS version do you use with GNS3 to run lisp on the 7200?
regards
Daniel
sergeybondarenko Fri, 03/15/2013 - 01:11
Hello Matt
Can you share with me the GNS3 configuration for LISP?
Also I shall be thankful for IOS.
Now I design a networking solution for a two data centers and I must ensure seamless mobility for a virtual machines. I would like to use LISP for the task.
Later I can provide you the results of the proof test.
danielkuhl Fri, 03/15/2013 - 01:55
Hi Sergey,
I recommend to use c7200-adventerprisek9-mz.152-4.XB10 for GNS3. I tested it with a LISP+GETVPN solution and it works great.
Daniel
danielkuhl Fri, 03/15/2013 - 06:07
Hi Sergey,
I build a little lisp lab for you which is similar to the real lisp project I am working for. Here are some short explanations:
DC: Represents some networks at the datacenter. These networks are the destinations for the trafic from the sites.
DCXTR: Lisp router for the datacenter with static routing to the datacenter networks 10.10.0.0/24 and 10.11.0.0/24
MRMS: Map-Resovler and Map-Server
Site1: 4 local networks and one management address configured as loopbacks will be propagated with lisp; ip sla with tracking to generate traffic to the datacenter
I skiped the GETVPN configuration and the redundant DC configuration to keep it simple. Hope it is ok in this way...
danielkuhl Fri, 03/15/2013 - 06:16
If there is someone interested I could add a GETVPN configuration to this small lab.
danielkuhl Mon, 03/18/2013 - 07:39
Hi Sergey,
I didn't try "lisp host mobility solution" yet, but I will go through the document this week and set up a test solution in GNS3.
