ASDM firewall interface graph
Aug 10th, 2012
Dear Colleagues
I am trying to get the graph for the outside interface of PIX fire wall, with the use of ASDM.
After selecting the desire interface and graph type, when clicking to show graph, nothing is coming
can you please high light if anything need to be enabled before this? or am i missing anything?
thanks in advance
Abhishek
Jennifer Halim Fri, 08/10/2012 - 21:49
  • Cisco Employee,
which version of pix and asdm are you using?
and what have you chosen within the graph attributes for the outside interface?
when using CLI, is there anything available for the outside interface (show interface)?
Abhishek Nagar Mon, 08/13/2012 - 04:14
hello all
re-installation of the ASDM solved the problem so I am discontinue this discussion,
thanks for your support
Ramraj Sivagnan... Sat, 08/11/2012 - 19:12
  • Silver, 250 points or more
Hi Bro
This sounds very much like an issue with your workstation, where you're viewing this graph. The possible causes could be your java version, browser setttings etc.
If you try from another workstation, do you still encounter the same problem?
hello all
Related Content
