AnyConnect Mobile
Answered Question
Aug 10th, 2012
  • Bronze, 100 points or more
I just installed an AnyConnect Mobile license on an ASA 5510 but haven't had time to do much else. Does the ASA require any further configuration to support mobile clients, or will the existing AnyConnect setup suffice?
Thanks.
Correct Answer by Karsten Iwen about 4 years 9 months ago
It's enough to install the license. You don't need any other config to let your mobile users in.
Overall Rating: 5 (1 ratings)
Correct Answer
Karsten Iwen Sat, 08/11/2012 - 01:54
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
Sharmeelan Mahe... Mon, 06/03/2013 - 21:42
Additional tasks can be done such as modify the client profile for the tunnel group if you would like to control "Connect on Demand". This feature allows the app to establish a vpn tunnel when a specific URL suffix is matched. This requires cert authentication
