N7K-VDC1K9 support question re: N7K-SUP2
Answered Question
Aug 10th, 2012
I've seen in the Configuration tool that the N7K-VDC1K9 license for +4 VDC is orderable for the N7K-SUP2.  I would like clarification on whether this license is required for use of VDC 1 to 4, or if it adds VDC 5 to 8 on the SUP2.  We have the N7K-C7009-SBUN-P1 license bundle with Advanced ENT included.  I've been confused and understood the SUP2 is only up to 4 VDC, and the SUP2E is up to 8.  The availablility of this N7K-VDC1K9 license, leads me to believe the SUP2 can support more than 4 VDC.  Please advise, as we would like to leverage more than 4 VDC on the SUP2 (not the SUP2E)
Paul
Correct Answer by Jerry Ye about 4 years 9 months ago
Hi Paul and Leo,
Just want to clarify SUP2 and SUP2E here.
SUP2 will support 4+1 VDC at FCS (NX-OS 6.1.1) and SUP2E will support upto 8+1 VDC. The VDC upgrade is for SUP2E not SUP2.
BTW, NX-OS 6.1.1 is posted to CCO as of right now.
Please check out the release note for more detail:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/release/notes/61_nx-os_release_note.html
jerry
Overall Rating: 5 (2 ratings)
Leo Laohoo Fri, 08/10/2012 - 18:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The only difference between N7k's Sup2 and Sup2E is the amount of DRAM.  Sup2 has 12 Gb of DRAM while Sup2E has 32 Gb of DRAM.
In regards to vDC, both Sup2 and Sup2E.  They both support 6 vDC and 1 admin vDC.  In the future, this number will grow to 8 vDC plus 1 Admin vDC (aka "stretched").
Correct Answer
Jerry Ye Fri, 08/10/2012 - 19:42
  • Cisco Employee,
Hi Paul and Leo,
jerry
Leo Laohoo Fri, 08/10/2012 - 20:11
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the update Jerry!
Devavrat Oka Fri, 04/26/2013 - 08:00
Do we need the N7K-VDC1K9 license per Sup2e or per chassis? If I have 2 7009 with 2 Sup2e each, do I need 4 counts of N7K-VDC1K9 or 2 counts of N7K-VDC1K9?
Dev
Jerry Ye Fri, 04/26/2013 - 08:18
  • Cisco Employee,
Do you have the Advanced Services Packages (N7K-ADV1K9)? This will give you 4+1 VDC day 1 (instead of 1+1).
N7K-VDC1K9 is incremental of 4 VDCs when you have the Advanced Services Packages.
VDC license is per chassis.
HTH,
jerry
Devavrat Oka Fri, 04/26/2013 - 08:59
Thanks Jerry, I found this on Cisco a few minutes after I posted that question...
N7K-VDC1K9—Enables support for eight VDCs on the Cisco Nexus 7000 Series Supervisor 2E module. This is a new license. One license is needed per chassis. A separate license is not required for each supervisor module.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/release/notes/61_nx-os_release_note.html#wp539647
Is the N7K-ADV1K9 per chassis or per sup?
Jerry Ye Fri, 04/26/2013 - 09:02
  • Cisco Employee,
N7K-ADV1K9 is per chassis.
jerry
Related Content
