WRVS4400N Router
Aug 10th, 2012
Just installed a new WRVS4400N router.  wireless working.  however refuses to let me log back via Ethernet cable in at http://192.168.1.1 given me 403 Forbidden, Access Denies, Management via WLAN is not allowed.  Was able to reset and noe braodcasting unsecured "cisco b" signal, but no way to get into router and set up security.  unsure what I have done.  HELP!
Tom Watts Fri, 08/10/2012 - 18:11
  • Green, 3000 points or more
Hi James,
Disable the wireless connection. It sounds you have both wired and wireless connection simultaneous.
-Tom
aostense Mon, 07/08/2013 - 06:46
  • Bronze, 100 points or more
Hi James,
As Tom states, disable the wireless NIC on your PC, and connect to the router (to port 1-4) with a wired LAN cable.
If http://*** doesnt work to connect to the router, try out https://***, and/or with another browser (or delete all cookies/saved passwords in your current browser).
Hope this helps,
Arne
